Anyone have creaky shocks?
Old Jan 17, 2001 | 02:09 PM
newmaxguy's Avatar
So, I've noticed that my car has a low pitched creak in the shocks or struts (I'm not car guru.) When I go over bumps, especially slower, like driveways or speed bumps, I hear the creaking. I can tell it's on all four wheels. Is this something to worry about you think? I've had the car for about 5 months and I baby it to death. I'm not sure if I remember hearing the sound before...it's probably not new.
Any ideas?
newmaxguy (93gxe)
Old Jan 17, 2001 | 02:53 PM
JonnyMax's Avatar
Hmmm... I get that as well.
Mostly when its cold though.
I have also been told that my Struts look worn.
My solution: just get the Tokico/eibach combo that the Max so badly needs anyways!
Old Jan 17, 2001 | 03:34 PM
Brandon90gxe's Avatar
yea i only get that in the mornings too when its cold.... its sounds like crap but i live with it..
Old Jan 17, 2001 | 04:06 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Same here......
usually after the car has sat in the cold for a couple of hours! I need those Sus Techs and Konis NOW!
Old Jan 17, 2001 | 05:17 PM
davis449
I have the same problem in the rear of my car and it's probably yhe springs because I just had the struts replaced. So I would assume it's your springs making the creaking noise. I also notice it more now that it's winter time and it's cold. The only difference between you guys and me is that mine do it all the time. I'm checking on the Eibach springs shipment tomorrow. I hope they come soon!
Old Jan 17, 2001 | 07:59 PM
Matt93SE's Avatar
STFU n00b!
It's the rubber bushings on the entire suspension.. this is normal on every car with rubber suspension bushings.. don't worry about it. it will go away when the car warms up.
if it REALLY bothers you, get some thick grease/lube and coat all the bushings inside and out, then stick it all back together..
that's a Looooot of work just to get rid of a few squeaks.
Old Jan 17, 2001 | 08:17 PM
JonnyMax's Avatar
So in that case....
Would the Poly bushings on the ST sways clear that up?
Old Jan 17, 2001 | 10:57 PM
Tom's Avatar
Tom
Same as everybody else
It's a bit chilly in Washington State right now with frost in front of my house in the morning. When I back out of my driveway, I can hear the rear end squeak/creak.
Old Jan 17, 2001 | 11:29 PM
Matt93SE's Avatar
STFU n00b!
Re: So in that case....
the funky white lube that somes with the poly bushings is what you need.. the bushings themselves won't solve the squeak.. it's the luuube man, the luuuube.
Old Jan 18, 2001 | 04:44 AM
OWhatAThrill's Avatar
Re: Same as everybody else
Think about how much we'd squeak if we slept outside at night...this 40 year old body would probably be very happy "just" to squeak. :-)
Old Jan 18, 2001 | 11:17 AM
JonnyMax's Avatar
Re: Re: So in that case....
hehe well I guess I will just have to luuube it good then!
Old Jan 18, 2001 | 02:21 PM
Blu Max's Avatar
Yeah my rears creak over speed bumps.
133k 92 SE, i haven't changed them since i had it at 85k,and doubt the previous owner did too. but i don't think i have worry about it anymore.
Old Jan 18, 2001 | 04:12 PM
speednsound007's Avatar
I creak too
over speed bumps...It's sooooooooooo annoying. I gotta replace RSB and springs early this summer, hopefully that will fix it if it's not just the cold weather.
PJ
Old Jan 18, 2001 | 08:36 PM
Sarah99GXE's Avatar
Maxima Princess
Correct me if I'm wrong, but (and I'm not sure about everyones car) so we have shocks?? I thought we just had struts in front & strut cartridges in back..at least I know I do...
Old Jan 19, 2001 | 05:20 PM
JonnyMax's Avatar
Yeah Sarah, You are right
I am just so lazy I use shock/strut to mean the same things.
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Stagnet04
Sep 14, 2015 11:28 PM
