Camber Kit Suggestions
I am going to purchase some intrax springs with koni struts. This will lower the 1990 GXE 1.75 inches. This will require a slight camber adjustment. I don't need a top of the line kit for this, and I will only have to adjust a degree or a little more of camber. What kit do you guys suggest?
Ingalls engineering sells a set of camber bolts for the front.. these cost about $35, shipped.
you can buy them at http://www.lightningmotorsports.com
look under suspension parts, and you'll find the link to ingalls parts in there.
the rears are the ones you usually have a problem with, and the adjustable camber kit on the rears is $$$$ for only 1 degree of camber.
i've done the intrax on mine...the camber isnt terrible, but i'm getting uneven tire wear. specialty products makes a kit that offers +/- 1.75, which should fully correct the intrax camber. its called the ez cam xr, which is the bolt type. its about $30 for the front kit. http://www.specprod.com the back was about $75 but i'm not gonna get that cuz my back camber is fine, no uneven wear that i can notice, so i'm not gonna fool with it. i'm gonna get the kit installed soon so i'll let you know how it comes out.
04-16-2020 05:15 AM
DC_Juggernaut
09-28-2015 04:07 PM
Pied
09-26-2015 03:29 PM
