My wheel feels like its loose when driving...
Old Apr 10, 2003 | 08:43 AM
DaBoxSE's Avatar
I've been feeling this "rattle" since I bought this car in July, but recently its been getting worse. Driving on flat road, I feel a rattle kinda like the driver side front wheel is shaking. I mainly feel it on the accelerator and lightly on the steering wheel. I've checked everything around the wheel (lugs, struts) an they seem fine and dont move, but I am really getting worried about it and its on my last nerve. I asked one mechanic and he said it may have something to do with the Axle. I guess it could be a number of things. I wanna hear what you guys think before I go have anyone take axles apart and such...
|C
Old Apr 10, 2003 | 08:45 AM
Jeff92se's Avatar
I'm needing a caw
Check the lower control arm ball joint and the control arm bushings. If worn, it could allows the wheel to wobble a bit. Or your wheel bearings could be loose or worn out. Can you move the wheel when you grab/shake it?
Old Apr 10, 2003 | 09:33 AM
DaBoxSE's Avatar
The wheel didnt seem to move when I shook it when I had it on a lift. I will check the control arm and see if thosse bushings are worn or not. I wish the weather was better over here, I would be under the car all weekend fixing things!
Old Apr 10, 2003 | 05:35 PM
nupe500's Avatar
Jedi Knight
Its your lower ball joint like Jeff said...I had the same problem with mine, the way to check it once the car is jacked up/ lifted is to put one hand at the 12 O'clock position and the other at the 6 O'clock position and pull in and out and feel the flexing...I'm pretty sure thats your problem...with that said...I have a brand new lower ball joint that I'm selling, I got it from courtesy but didn't need it for the other side...I'll let it go for less than w/the discount plus shipping...or shoot me an email. oekundar@hotmail.com
good luck
Old Apr 10, 2003 | 09:05 PM
Matt93SE's Avatar
STFU n00b!
If you have to ask, then you need to take it to a shop. otherwise, you'd know where to look.
i.e. it could be control arm bushings, tie rod ends, a bad strut, wheel bearing, ball joint, axle......
Old Apr 14, 2003 | 09:33 AM
DaBoxSE's Avatar
I took another look at it this weekend and its the strut. Basically the wheel "dribbles" on the ground. I wish it would have lasted a little longer so I could save money for some Tokico's and Eibachs, but I need the money for my transmission. Both front struts are bad from the looks of it. When I spoke to me mechanic, he didnt think that it was the only problem. I'm gonna put it up in the air again tomorrow.
Old May 14, 2003 | 08:31 AM
timmyrig89's Avatar
go to a shop and get your tires balanced that could be the problem
Old May 15, 2003 | 05:49 AM
DaBoxSE's Avatar
Im getting a pair of Yokohama ES100s installed tomorrow. The problem turned out to be the struts and strut mount on the driver side. I am buying a set of Tokico Blues on Saturday, and currently shopping for eibachs. So pretty soon it will be all gooood.
dcam0326
Sep 8, 2015 11:02 PM
