bad MPG
Old Apr 14, 2003 | 05:05 PM
Maxima90SE's Avatar
bad MPG
i think i have a bad MPG. in the city i am getting like 19 or 21MPG. This is kinda low i think. i have new spark plugs, wires, distributor and rotor, fuelpump and filter, CAI and exhaust. What can i check to see maybe it is bad or what should i do to make my MPG better. SOmeone said to get the electrion thing for fuel and air, and it made his better.
Old Apr 14, 2003 | 07:00 PM
Sudesh's Avatar
Re: bad MPG
If you want to save a little money, examine the car yourself.
If you don't have a multimeter, buy one. Get an factory service manual. Use the multimeter with the guidance of the FSM and test the various sensors on the car. For example:
a) Oxygen Sensor.
b) Throttle position sensor
c) Coolant temp sensor
d) Mass air sensor...etc etc etc
whatever doesn't read within specs, replace it (if it can't be adjusted).
Check out your fuel injectors, make sure they're not leaking. Use a can or two of throttle body cleaner.
Old Apr 14, 2003 | 09:12 PM
The Sleeper's Avatar
21 in the city isn't all that bad. I'm not sure how many gallons are in a tank, but i generally get 250-300 miles out of a tank. When i fill up, it's about $25 at $1.69 a gallon, that means i'm getting 20mpg average. i consider that pretty good for a lead foot.
chisam14
Nov 6, 2018 08:56 PM
ef9
Oct 4, 2015 08:43 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
