What is PVC valve and why should I change it
Old Apr 21, 2003 | 07:23 AM
john402052000's Avatar
I own a 92 Maxima GXE. I'm going to tune it up in the next couple of weeks -- its been idling and running sort of rough and I figure its time anyway. I was going to replace the plugs, wires and distributor cap. In one of the maintenance links I saw the PVC valve mentioned. I was wondering what this thing does and how important it is (and how dow you know when) to replace it.
thanks
Old Apr 21, 2003 | 07:41 AM
Michael's Avatar
Back in a 3rd Gen.
Re: What is PVC valve and why should I change it
thanks
That is PCV not PVC. PCV stands for positive crankcase ventilation. It is a check valve (only flows in one direction) that evacuates pressure from the crankcase by pulling it through the intake vacuum. This helps to maintain piston ring seal, helps prevent oil leaks from pressure building up and blowing the engine seals...probably other things too.
replace it because its not expensive.
Old Apr 21, 2003 | 10:26 AM
buzzhd's Avatar
I have read some posts here in the past. This PCV is very difficult to change it, simply because you don't the strength to take the old one out. So what exactly do I have to do in order to replace it if I am not stronger enough? Where is PCV located?
thanks for the further info.
Old Apr 21, 2003 | 11:21 AM
Michael's Avatar
Back in a 3rd Gen.
its hard to change on the VE because of the location but that has nothing to do with how strong you are.
the VG (in all 3rd gens except 92-94 SE) it is real easy to replace because it is right up there on the intake.
Old Apr 21, 2003 | 12:13 PM
crazy4maxima's Avatar
where the red circl is that is where the pcv is located not hard to change and its done in less than 5 minutes
Old Apr 21, 2003 | 04:42 PM
buzzhd's Avatar
thanks for the pic. what year and model do you have? I don't see the brake fluid reservior...
JoshG
51
Sep 21, 2015 10:41 PM
bumpypickle
Sep 20, 2015 08:22 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Steven Orozco
Sep 12, 2015 10:41 PM
tardrex
Sep 11, 2015 07:35 PM
