gas leak
Old Apr 22, 2003 | 01:15 PM
1990MaximaGXE's Avatar
gas leak
gas is leaking out of some where near my filler tube but i cant find a hole anywhere. can someone please help me out with posible areas to look is this a common problem. please help.
Old Apr 22, 2003 | 01:18 PM
cneary812's Avatar
Re: gas leak
Man I wish the search worked...
If you haven't had your fuel filler pipe replaced via recall then get it if you can, otherwise check the fuel hose connecting the filler pipe to the tank. You most likely have a small tear at the fitting. Get a new section of hose or go buy some fuel line tape and fix the hose.
Old Apr 22, 2003 | 01:20 PM
thank you ... i know i wish the search worked 2
Old Apr 22, 2003 | 01:27 PM
cneary812's Avatar
No problem
Old Apr 22, 2003 | 11:46 PM
rymo926's Avatar
gas bypass tube connected to the filler tube and the tank might be it.
Old Apr 23, 2003 | 12:28 AM
crazy4maxima's Avatar
yes i had a breather that runs from my gas tank under the rear left wheel and it had worn out , so everytime i filled up with gas i would lose most of it b.c when i turned off the max, the pressure
in the tank was released and then the tube would expand and the gas would leak from the crack.,. very dangerous, i dint notice til i kept smelling gas and my nose lead me to the rear where i litteraly saw dribbles of gas coming down.. quick fix..
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
