maf adaptor
maf adaptor
i bought an intake adaptor off ebay and they sent me a square maf addaptor and the vg is rectangular so i turned it so that i could get 2 screws in will this be alll right i tightened them really tight.
Re: maf adaptor
the metal is not wide enough so there is nothing to drill
charlie
Originally posted by rymo926
me too but i'm sure it's leaking air in, maybe try a home made gasket.
Just remember that there are 4 screws in there for a reason. 2 may seem to work fine but you could be sucking in dirt from that opening and over time... you can fill the rest...
Same thing happened here. All I did was turn the adapter diagnally and screwed them into the bottom left and upper right hole. It was perfect. I've checked it every other week for the past couple o'months and its still there. Never had to tighten once.
ummmm yeah...so much for proper sealing and preventing the MAF from being damaged.
Originally posted by MAXMAN91
so what can i do addae to fix it.b/c i only have 2 holes screwed in. do i need to make 2 more holes. or can i buy a better one somewhere else?
I'd just get it from Cattman, but if you go with Lightning MP, I think the "type M" is what you want. most of those Ebay Nissan MAF adapters are for the 4-cyl models which I think have a different bolt pattern("type N").
Because you wrote that, I went back and checked my MAF. Its ****ing flawless. No cracks, no opennings. Damaged you say....I've been using it this way for months and its still good. You crack on me when theirs some other guyz that has it screwed in on one side! So **** off. ****ing loser.
I'm sick of his ****. I know about the dangers. My methods are different, but it works better than the other alternatives. I'm not dumb enough to risk exposing one side of my adapter to dust (no offense to those who have). Da-Max needs to stop picking on me cause if I ever meet him in person.
riiiiight.....
I'm friggin terrified
look, look, my hhhhaannnds aaree sshakking sssooo mmmuch IIII caaannn bbbarellly tttyppe....save it buddy.
If only you knew...If only you knew who I was and what I would do.
Just the way of the Forrum dude
No hard feelings.
Now that's the way to respond. You tell him...
TallTom
57
Oct 14, 2025 05:16 PM
magiconthetire
Oct 26, 2015 09:03 PM
ballerchris510
Sep 10, 2015 09:35 PM
