Question about tires and springs (Craig)
Old Apr 27, 2003 | 03:47 PM
my2ndmax's Avatar
I have just purchased a set of 97-99 5 spoke wheels. I was just lookin at Craigs page and thats exactly the look that I want. My two questions are what size tire do I need for these wheels and Craig what lowering springs are you using I want that exact height that you have not too low but no wheel gap.
Thanks in advance.
Old Apr 27, 2003 | 03:57 PM
Clayton's Avatar
Re: Question about tires and springs (Craig)
Thanks in advance.
You need 215/55/16s, and a set of Eibachs will you give you the height you want.
Old Apr 27, 2003 | 07:01 PM
my2ndmax's Avatar
Re: Re: Question about tires and springs (Craig)
What does the first number on the tire size mean. Im asking because someone I know is selling his 205/55/16s
Old Apr 27, 2003 | 07:12 PM
Clayton's Avatar
Re: Re: Re: Question about tires and springs (Craig)
Width of the tire. 215 is the recommended tire size for that wheel. 205 would probably fit fine, but I wouldn't put those on my car.
Old Apr 27, 2003 | 08:11 PM
D-sta's Avatar
Yes 215/55 is recommended. I have the 99 SE-L rims and I have tokico and eibachs. Craig has Eibach springs and kyb gr-2's shocks.
Old Apr 27, 2003 | 08:16 PM
my2ndmax's Avatar
Ok guys thanks. I'll go with the 215/55. Second question do I have to change my shocks when I get the Eibachs if not what will happen? Im clueless with suspension upgrades so thanks guys.
Old Apr 27, 2003 | 08:38 PM
«§»Craig B«§»'s Avatar
like the others have said, I have eibachs with 215/55/16 tires and KYB GR2 struts
you SHOULD change your shocks when you put in lowering springs, the springs will put more load on the shocks and wear out your stock ones pretty quick
the best and most expensive shocks are Koni, next up are Tokico and cheapest are KYB GR2
I got mine from www.eatricezone.com but you can get them a little cheaper than that and have been happy with them
you should also replace dust boots when you do the springs/struts (check out the FAQ link for how-to instructions to see what's involved)
your car is gonna look sweet
D-sta's Avatar
Well its suggested because since a lower spring will put more stress on the same shock it will wear it out quickly and soon you will need a new set of shocks. Since when installing springs you have to remove the you might as well replace it with new ones. You can get all 4 shocks for like $180.00 shipped from www.foreignautoparts.cc or www.alloemautoparts.com
Old Apr 27, 2003 | 08:51 PM
my2ndmax's Avatar
Thanks to Craig and Dsta as usual and thanks Clayton. I will get the tires shocks and springs this week and I'll post some pics of my car next week I gotta wait to take pics since somebody broke into my car so I have 5% tint all around and one clear one so as soon as I get that window tinted I'll post some pics.
Old Apr 27, 2003 | 08:55 PM
D-sta's Avatar
no problem anything else shoot me an e-mail anytime.
Old Apr 27, 2003 | 09:45 PM
Menel's Avatar
1992 Maxima SE
yea ive got 16" nissan 240sx rims and previous owner ran 205/55/16 for some reason
need new tirse soon and im gonna switch to 215/55/16
got some friends pushing me to do 225 but im probably gonna ***** out
Old Apr 27, 2003 | 09:50 PM
D-sta's Avatar
I had 225/55 Pirelli P7000 Supersports and on the passenger side they rubbed on the inside. Now I have Bridgestone Potenza RE950's 215/55 and they don't rub at all and are excellent tires.
Old Apr 28, 2003 | 08:59 AM
nupe500's Avatar
Jedi Knight
I think that anything larger than 215 will rub...I had 235s on my 17s and the insides wore..but on my 4th gen...they fit perfect and no rubbing...another reason 3rd gens suck!... j/k of course (I still have mine)
Old Apr 28, 2003 | 09:57 AM
Jeff92se's Avatar
I'm needing a caw
I have 17x8 w/ 235-45 w/ no rubbing. I also have 16x8 w/ 225-50 w/ no rubbing Both for sale.
Old Apr 28, 2003 | 12:56 PM
Clayton's Avatar
How about those trim pieces????
Old Apr 28, 2003 | 01:33 PM
Jeff92se's Avatar
I'm needing a caw
I tried to get them off but I couldn't see how to do it w/o mangling them. If you have some ideas let me know. I'm sorta stumped.
Old Apr 28, 2003 | 02:43 PM
makeuw3t's Avatar
what size tires are suppose to be on a 93 gxe?
Old Apr 28, 2003 | 04:50 PM
Clayton's Avatar
I think it's 205 or 215/65/15s. I can't remember for sure about the width.
Old Apr 28, 2003 | 06:40 PM
Michael's Avatar
Back in a 3rd Gen.
205/65/15
Old Apr 30, 2003 | 09:00 PM
shoult's Avatar
It's REALLY suggested becasue you have to remove the strut from the car to install the springs. So you would have to do the same labor twice. Also, since you are removing one suspension mount point when you remove each strut you need to get the realigned each time.
Also, 215/55R16 are the stock size, but you can run a 225/50R16 and have a little more meat on the road, about the same diameter so your speedo error isn't affected much and not lose much ride quality.
Just my 27 cents....
Old Apr 30, 2003 | 09:02 PM
shoult's Avatar
Originally posted by nupe500
I think that anything larger than 215 will rub...I had 235s on my 17s and the insides wore..but on my 4th gen...they fit perfect and no rubbing...another reason 3rd gens suck!...:D j/k of course (I still have mine)
Your insides probably wore because you didn't adjust your camber.
dank4us
34
Jun 10, 2024 03:45 AM
Matt93SE
May 24, 2019 02:58 PM
homeyclaus
Sep 3, 2015 06:15 PM
twotonezed
Aug 16, 2015 11:41 AM
