91 se Valve Cover Removal
Old May 1, 2003 | 12:41 PM
chrispy's Avatar
i am having issues with my distrubuter not turning, the gear that turns the distrubuter doestn turn, so i want to remove my valve cover, haynes doesnt help much cause they dont do it on MY car
any helpful hints would be greatly appreciated
Chris
Old May 1, 2003 | 01:15 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: 91 se Valve Cover Removal
Chris
take off the upper intake manifold and loosen all the screws on the valve cover. you should be able to pull the dist but setting it to TDC. good luck.
Old May 1, 2003 | 01:23 PM
chrispy's Avatar
i was afraid i would have to take off the intake manifold.
now i get to figure that one out
Chris
Old May 1, 2003 | 01:40 PM
DanNY's Avatar
Ad·min·is·tra·tor
Chris
whip out the credit card and start ordering some gaskets.
like i said..check if u can pull the dist out 1st and check before you go racking your brain trying to get the valve cover off.
Old May 2, 2003 | 12:42 PM
chrispy's Avatar
i already did remove the distrubuter, and the engien doesnt spin the gear that spins the distrubuter
for ease of use, and troubleshooting reasons i took off the timign belt cover, the belt is trash
so i need to tear down that side of the engine
and IFF (if and only if) everything in there seems smooth then i will jsut put a new belt on, but i am afraid that there may be something mroe serious like a broken camshaft in there
btw, if anyone that has expertise lives near terre haute indiana, and would love to spend a friday night busting their knuckles instead of with a girlfriend or etc, please message me, i will provide free pizza
Chris
Old May 2, 2003 | 03:10 PM
maxdout92se's Avatar
i'm confused...pleeze don't flame...the SE has a distributor cap??? and you said the timing belt was trashed...i thought SE had a chain!!
Old May 2, 2003 | 03:22 PM
Lordrandall's Avatar
maxdout92: 92-94 SE = Coil on Plugs, and timing Chain
89-94 GXE and 89-91 SE = distributor cap and timing belt.
Old May 3, 2003 | 10:26 AM
chrispy's Avatar
that correlates with my findings of distro cap and timing belt
any advice on changing a timing belt, and what to look for on causes for breaking (belt is only 40k old)
Chris
tgreen
Oct 18, 2015 06:18 PM
JoshG
51
Sep 21, 2015 10:41 PM
Max139617
Sep 20, 2015 07:25 PM
Max139617
Sep 20, 2015 07:09 PM
tardrex
Sep 11, 2015 07:35 PM
