5speed conversion on 3rd gen
Old May 1, 2003 | 10:12 PM
Turbo95Max's Avatar
Turtle turtle... Moderator
its been done before rite? juss wondering
we're in the process of doing a pathfinder motor swap and 5speed conversion on a 91 Max. i was wondering if anyone has done the 5speed conversion. im assuming its simlar to a 4th gen 5speed swap but anything i should know or look out for? thanks for the tips.
Old May 2, 2003 | 07:04 AM
lophix's Avatar
Re: 5speed conversion on 3rd gen
you of all people should know that:
1. this has been done...countless times..
2. the search button exists for that very purpose..
now search before you get spanked...too much info to spill out on one page...your best bet is to sift and read through them all.
good luck.
Old May 2, 2003 | 10:02 AM
Lordrandall's Avatar
Hey Matthel, are you guys using the VG33 from a Pathfinder? Take pics!
Old May 2, 2003 | 10:11 AM
Jeff92se's Avatar
I'm needing a caw
Matthel, contact Kaleb. He's your best bet. He works at courtesy nissan.
Old May 2, 2003 | 10:14 AM
nismo1989's Avatar
VG33 in a Maxima, huh?! I didn't think the bolt pattern was the same for the tranny swap. Good luck on that one!! Take plenty of pics if you can...
Old May 2, 2003 | 11:24 AM
KLoWnPR109's Avatar
I might be able to let you know about any hangups in a week or two
Old May 2, 2003 | 11:42 AM
Maximan190's Avatar
the general jist is that it CAN be done on just about any car... its just the level of difficulty that varies from car to car
kaleb, mykizism, dmontzsta, (and me in about a month) are a few people you can talk to who've swapped 3rd gens
Old May 2, 2003 | 01:15 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
reread his post
Old May 2, 2003 | 01:35 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Originally posted by Chris91SE
reread his post
it cuaght me at first too
Old May 2, 2003 | 02:04 PM
reread his post
What is it about that statement that doesn't say Pathfinder motor swap and 5-speed conversion on a 91 Max to you?
Old May 2, 2003 | 03:29 PM
surfermax92's Avatar
It's a 92 max Matthel, and Geoff, I hope you're wrong about the tranny- all the research I've done says it'll all bolt up.
Old May 2, 2003 | 04:01 PM
DA-MAX's Avatar
Re: Re: 5speed conversion on 3rd gen
I see what Chris is saying, but you know what now that I read it AGAIN, you're right...it does look like they are doing the 3.3 swap into a Max. Nice!
Old May 2, 2003 | 04:34 PM
Nismo87SE's Avatar
Is this the VG33E or VG30E swap? The pathfinder is supposed to have a better IM however I don't see how. I still makes the same power as the VG in teh Z31 and 3rd gen, however the torque is about the same as the 3rd gens too. VG33 would own though
Old May 2, 2003 | 06:08 PM
It's the vg33e Ari. We're using the vg30e intake manifold, keeping the vg33e heads and adding the Euro cams. It will be fun when its done.
Old May 2, 2003 | 10:29 PM
Nice! I'll be up there in August for an inspection.
Old May 3, 2003 | 09:19 AM
Taegost's Avatar
What is the difference in the engines really besides the fact that it's 3.3L? I'm thinking about doing something similar (What I'm planning I actually need 2 different engines, 3 will make it easier) and I'm trying to do a little bit of research before I start seriously thinking about it
Old May 3, 2003 | 03:22 PM
sndmaxx's Avatar
hi guys i have a 1990 gxe and i had a tranny problem , i was driving down the street all fine one sec ,came to a stop sign and went to step on the gas , the motor was running but the car wasnt realy moving. made it home fine , thanks for asking , didnt move the car for two days , went to try to take the car to aamco but were closed , funny thing this was to weeks ago and the tranny is fine no problems since that day anyone had this happen to them .
also about this tranny swap is it worth it to pick up a pathfinder tranny for my car ,would it fit, or should i just pick up one from my car and swap that one ......thanks any help would be fine ....i would use the search but reading from up front knowhow for me is better...thanks again
Old May 3, 2003 | 10:39 PM
Taegost- I'll know for sure when it all goes in, but the only differences that I can think of are the displacement, the heads (the 33e heads are a bit more open), the intake manifold (though our vg30e manifold fits on), the oil filter placement (Which can be switched back to orig.) and the oil pan. It seems like a pretty simple swap as far as engine swaps go.
sndmaxx- I'm using a 96 pathfinder engine- not the transmission. The pathfinder is RWD or 4WD- so it has a different transmission and different engine positioning. You'd be best off using one from an 89-94 GXE.
Old May 4, 2003 | 01:33 PM
maximum810's Avatar
For the time and effort it takes you to tell a person to "use the search button", you could of already answered their question.
Old May 9, 2003 | 12:46 AM
Turbo95Max's Avatar
good luck.
i dont see why....i dont follow 3rd gen forum, i dont have a 3rd gen so i dont follow it much either.
kjlouis
Sep 14, 2015 11:22 AM
I<3 A32's
Sep 10, 2015 11:07 AM
Hdnseek
Sep 9, 2015 05:55 AM
Lowered_a33
Sep 1, 2015 07:49 PM
