What is a good strut/spring combo for the front?
Old May 4, 2003 | 03:23 PM
Hornswoggler's Avatar
Hi! I am new to this forum. Nice site!
I have a '93 GXE with 140k miles (it's my daily commuter) and it's still kickin strong! Only problem right now is that it needs some new front struts. I'm on a suspension upgrading roll right now since installing coil-overs in my BMW M3, and would now like to improve the handling in my maxima. My question is this:
What does everybody recommend for replacement front struts? This is my daily driver, so ride comfort is important (if I want handling I'll drive my other car). I have noticed a few brand of struts for the 3rd gen Max (Boge, KYB, Koni) and wondering what is the best compromise between performance and ride comfort? I don't really need to lower it.
Thanks in advance!
Old May 4, 2003 | 04:15 PM
Matt93SE's Avatar
STFU n00b!
Welcome to the board.. I suggest reading other posts on the forum or using the search function for stuff like this, as it's very commonly discussed.
as for a suggestion, I'd say go with Tokico struts. if you want to lower it a bit also, do either Eibach or Suspension Tech springs... if you don't want to lower it, get the suspension tech sway bar set. helped the car corner a LOT better.
Old May 4, 2003 | 05:09 PM
I'm not looking for *****-to-the-walls performance... but if i can replace my struts with something better than stock for roughly the same price, I will. I don't plan on lowering it, but its ok if it is lowered.
Old May 4, 2003 | 05:16 PM
D-sta's Avatar
Tokico struts shold be good enough for what you're looking for.
Old May 4, 2003 | 05:50 PM
How are Tokico's when combined with stock springs? Is that an ok combination? I may not want to spend any more than $100 per side and i'm doing the front only. I can purchase replacement (i assume stock or similar) for about $50 per strut. I'll pay a little more (even double) if there is a decent increase in performance. New springs would not be cheap... especially if it meant I had to do all 4 instead of just the front.
Old May 4, 2003 | 05:53 PM
D-sta's Avatar
You can try shox.com.....I paid $550.00 shipped for tokico's and Eibachs from stillen who are known to charge a bit more. $300.00 for tokicos and $200 for eibach springs. I can't help with how just shocks and stock springs would feel like.
Old May 4, 2003 | 06:34 PM
Matt93SE's Avatar
STFU n00b!
you'll definitely want to step up to the Toks over KYB of factory then. they're around $100 per strut on the front, but definitely worth it. anything else (other than springing $550 for a set of Konis) and you'll kick yourself every time you switch between the M3 and the Max.
Either will work fine with stock springs, but I highly suggest going with a little stiffer spring also. maybe just picking up a set of used SE springs for a 3rd gen will make you happy. I've got a set of fronts, but the rears are somewhere in a junkyard with the rest of my parts car when I scrapped it.
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
KGMtech
Aug 18, 2015 09:21 AM
twotonezed
Aug 16, 2015 11:41 AM
