need help: my key was broken
I snapped my key while attempting to open my car door. Part of the key is still in the lock ... and of course, I cannot locate my spare keys.
what should i do?
can i get another key from the dealer?
any suggestion?
thank you in advance.
what should i do?
any suggestion?
Re: need help: my key was broken
what should i do?
any suggestion?
what should i do?
any suggestion?
prepare to spend alot of cash.. like 8 bucks..
wd-40 all ur door locks.. they will feel like new
your keys may have come with a number on a metal tag. With that tag you can goto the dealer and get one made with it. If you have the keyless, use that to get in. If you can, try to use a pair of pliers and try to get the broken part out. If that doesn't work I guess you can always take the door apart and see where it takes you
Originally posted by crazy4maxima
do what i do chage you keyless entrey pass code and use that to enter the max.. now starting it would be a problem...
i still have my key broken in the cylinder door... cant get it out
Re: Re: need help: my key was broken
Originally posted by ChrisCheezer
try to fish it out.. if and when u get the other half out im sure any key maker can Fab. another car key for u.. they are good at what they do.
keyless entry is the answer and relatively easy to install...heck! i did it myself and i'm a dodo when it comes to working on my car....my key is almost split in half but i have spares....at least 4. once again, wd40 has little lubricant in it...
bend a safty pin into a hook and pull out key
A safty pin, not a needle, can be bent into a hook, like a 1/16th an inch of the end of the pin. Use a pair of pliers to bend the safty pin into a hook. Slowly and carefull fish the end of the key out. If you can't let someone else try. The big end of the key has a 4 digit code on it. With that the dealer can punch out a new key that will be perfect. If the dealer has any valet key blanks you can use the same code to make a valet key. If you have no 4 digit code on what is left of your key, some dealers, the one who sold the car, can look up the key code. If not, take out one of the door cylinders and it should have a key code number on it.
Sven
Sven
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
