Tap and Die Set(Wheel Studs)
search google for how to use a tap and die, I'm sure you can find tons of info there
but why are you using it for wheel studs? those are supposed to be pressed into the studs or you can use lug nuts with a couple washers as spacers to pull it into place in the hub - check out the online chiltons manual for more info - I'm pretty sure I saw that trick on there (I know it's been posted on .org but search is down right now)
CorollaULEV
30
Aug 9, 2021 08:11 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
