CAI install question
Old May 18, 2003 | 10:13 AM
atulb84's Avatar
So I finally got around to buying the two replacement rubber couplings i needed for my wsp cai (3"). I remember when i first installed it, it took me 45 minutes just to put on the couplings. I was wondering if there is anything I can do to make them slip on easier. I had to cut my old ones at the ends so that it would be a little bigger to slip on, but im sure some air escaped when i did that. Please let me know if you guys have any suggestions for an easy replacement. Thanks.
Old May 18, 2003 | 10:19 AM
tmnismo91's Avatar
Rubbing alcohol
Try using a little rubbing alcohol on the outside of the piping.
-Sean
Old May 18, 2003 | 10:35 AM
«§»Craig B«§»'s Avatar
use a little bit of soapy water on the inside of the rubber coupling to help it slide on easier
Old May 18, 2003 | 10:41 AM
atulb84's Avatar
sweet. thanks for the quick replies fellas. i appreciate it.
PH98I30
Jan 9, 2025 08:08 AM
Maxima_Joe
Nov 25, 2015 08:19 AM
lowpost99
22
Sep 2, 2015 04:38 PM
BGTONIO1991
Aug 11, 2015 07:38 AM
