Maxima gulping clutch fluid. What to do?
Old May 19, 2003 | 07:13 AM
SmithAtlanta's Avatar
I keep filling up the slave cylinder with clutch fluid(DOT 3 brake fluid that is) but I'm not seeing any leaks and the clutch seems to have good pressure. Should I just go ahead and replace the slave cylinder, lower cylinder, and hose?
Old May 19, 2003 | 09:34 AM
Matt93SE's Avatar
STFU n00b!
more likely it's the master cylinder..
look on the inside of your firewall at the top of the clutch pedal, and see if you can see the fluid leaking out there. if so, then you need to rebuild or replace your amster cylinder.
Old May 19, 2003 | 04:39 PM
Would you buy the whole new Master cylinder or one of those refurb kits that has the rubber pieces and a new spring? Would you buy OEM or local parts store? Just wanted your opinion....
Old May 19, 2003 | 04:41 PM
Jeff92se's Avatar
I'm needing a caw
Buy a new one. It's too much of a pain in the butt to put a rebuilt one in there. It's your $ and time though!
Old May 19, 2003 | 11:21 PM
Matt93SE's Avatar
STFU n00b!
I simply rebuilt the one I had in my car. the time to rebuild it isn't much, but I also had the proper tools to hone the cylinder walls. if you don't, then I recommend just buying a complete new/reman unit and installing it.
Mrbizness1
Aug 18, 2015 08:43 PM
maxima-junky
Aug 13, 2015 09:59 AM
MikesChevelle
Aug 10, 2015 10:53 AM
sc10692
Aug 9, 2015 09:37 AM
