running wire
Old May 20, 2003 | 12:58 PM
kingrye's Avatar
running wire
i cant find a spot for my 8 gauge wire to run trew in my fire wall can i get some help or advice??
Old May 20, 2003 | 02:04 PM
shavedmax's Avatar
drill a hole above the brake pedal, in between the booster and strut tower hole. that's what i had to do . just make sure you wire loom it so it doesnt short out
Old May 20, 2003 | 03:17 PM
subs1000w's Avatar
or use a gromet
Old May 20, 2003 | 10:34 PM
chchmax's Avatar
I managed to get mine through a hole on the left side of the car, i just stretched out a coat hanger, and pushed it it slowly with someone looking inside for where it came out. Then i taped the 8 gauge cable to the end of the hanger and pulled it through..
The hole is where one of the main looms goes through the firewall, behing the strut, its quite a large hole, takes a bit of playing to get it through though.
Hope thats not too long or confusing
Old May 21, 2003 | 03:04 AM
kingrye's Avatar
what kind of drill bit should i use
Old May 21, 2003 | 02:53 PM
shavedmax's Avatar
a metal one! , j/k, make sure you go from small to large, progressively making the hole bigger or else youll snap the bit
Old May 28, 2003 | 07:37 AM
91maxi's Avatar
make a small pilot hole with a Metal drill bit and then switch bits to a bigger bit and keep drilling the hole till u find the rite size to get the 8 guage wire threw, people told me after in done silicon the hole closed, still havent done it but frankly i dont think its needed.
Old May 28, 2003 | 07:41 AM
chchmax's Avatar
crikey!, hope you got a fuse in there then! otherwise your battery is gonna make one hell of a mess under there when the wires shielding is eventually worn through!
wyobbagy
Jan 3, 2023 12:03 PM
The Frye
Sep 2, 2021 11:03 AM
9aj9
Apr 5, 2020 12:11 AM
captchaos
Mar 15, 2016 12:18 PM
ballerchris510
Sep 10, 2015 09:35 PM
