18x8 ?
Re: 18x8 ?
Originally posted by GReDdyXMaXiMa
Hey I'm wondering if 18x8 would fit in the rear since I have 18x7.5 and i had to use two 1/4 spacer left and right on the rear. I doubt it ll fit anyhow cuz it is too big . Maybe I m wrong. Does anyone know about it ?
Man , your car looks great! Isnt that WRX taillights? Yeah , thats what I thought it wont probably fit if i get bigger spacer then there ll be no room for lug to bolt in.
Originally posted by Lordrandall
18x8 with a 30 offset is just about perfect.
shavedmax, can you shrink that sig pic a bit?
I see you have some in the rear, any in the front?
I may wanna get a set of spacers/studs to push out my 4th gen rims a little bit closer to the fender lip (not as far as your rears though)
Yes it will fit your car. See here:
https://maxima.org/maxfaqs/sub_tires...#TiresWheels_3
Very bottom.
Very bottom.
Hey , would 38 mm offset fit ? I bet it is too deep.
click here: eBay Motors item 2416982468 (Ends May-28-03_22:40:32 PDT ) - HP EVO 18X8" Wheels w/Tires 5x114.3mm Lugs
I wish I had a dollar every time I saw this same post...
I have 17 inch rims on right now, and they are 8.5 inches wide. I have no spacer. I had 18X9s on there before... and had to use a 5/8" spacer on the rears because it's lowered and the offset didn't work. It's all about the offset, not the width of the rim necessarily.
Originally posted by Maximan190
hey rand, where did you get your spacers from?
That link is on my Homepage on the wheels page as well.
I have 20mm adaptors with studs built in on the rear, and 5mm spacers on the front. Hub-centric from Crow Auto. The perils of running 16x8 wheels with a 50 offset
The things I do for a cheap set of 16 lb. wheels.The wheels might be for sale soon, have to find a set that will fit over my Z32 front calipers.
BTW, check out the pics, the rears aren't so far out with my new spacers.
aznbluboy
Feb 22, 2002 08:13 PM
Vic
Feb 13, 2001 07:49 PM
