Q: about timing
Old May 28, 2003 | 06:42 PM
Gjohnson's Avatar
Q: about timing
Is this what stock timing should look like. (It's a pic from Craig's page on advancing timing. Thanks Craig) Because My timing has a huge gap above the nut. ( pink circle area) Which would mean that my timing is very retarded. Is this correct? If so this might be the reason for all my hesitation and stalling problems. Sorry I don't have a timing gun.
http://maxima.cardomain.com/member_p...00_27_full.jpg
Old May 28, 2003 | 08:33 PM
Steves92MaxSe's Avatar
Most likely with this particular bolt having a huge space over it then your car is most likely retarded. Be careful when moving it toward the advanced side.
Old May 28, 2003 | 08:37 PM
Aaron92SE's Avatar
NWP Engineering.com
Re: Q: about timing
It's hard to tell in that photo, but that looks to be about 20 degrees. In MY experience, 5 degrees advanced has about a 1mm gap in that circle you drew. I think stock timing has about an 1/8" gap. But this is not the way to gauge this... you really need to get a timing light. Just hook it to your #1 cylinder and hope it gets a signal. That is the easiest way to get an idea of what your timing is set at.
The more accurate way is to remove the #1 coil pack and connect it to the spark plug with a plug wire and then clamp onto that wire. Hope this helps.
OH yeah.... this is a better photo of what 20 degrees looks like. Thanks Craig!
http://www.geocities.com/craigbracegt/maxima/timing/CPS2.jpg
Copy and paste this URL.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
trungg86
Sep 4, 2015 04:58 AM
Wareagle92
Sep 3, 2015 07:18 PM
