Something else ive noticed that is different on my auto vs my 5sp parts car..
Old May 29, 2003 | 08:33 PM
Maximan190's Avatar
At the fuel pump.. on my auto theres 2 wire harnesses and on the 5sp theres 1
auto
5sp
Old May 29, 2003 | 08:43 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
i'm 99.9% positive that mine only has 1
Old May 29, 2003 | 08:48 PM
|Bijan|'s Avatar
UCF Lexus
isnt yours auto chris?
Old May 29, 2003 | 08:55 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
Old May 29, 2003 | 08:57 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
well are they both connected to something under the cover plate?? take it off and see...thats very strange!
Old May 29, 2003 | 09:08 PM
LegitMafiaBoss's Avatar
Re: Something else ive noticed that is different on my auto vs my 5sp parts car..
auto
5sp
Are any parts available for sale from your parts car? i.e. stick shift ****, driver side seat base, license plate holder, some cotter pins, 1 adjusting cap, swap rims/tires my tires are all worn...a few other small things
Old May 29, 2003 | 10:00 PM
shock211's Avatar
my 92 gxe auto has only one harness....this is quite odd
Old May 29, 2003 | 10:28 PM
GReDdyXMaXiMa
Maybe u got N20 in your car
Old May 29, 2003 | 10:34 PM
«§»Craig B«§»'s Avatar
I can tell you for sure that my 93SE 5spd has 2 harnesses also, not sure what the difference is; maybe black cars get two harnesses because they're better
I had the back seat out today so I could put some big stuff in there and move out of my apartment
Old May 30, 2003 | 07:14 AM
D-sta's Avatar
I doubt its because of color, I just think that Nissan peeps while making 3rd gens may have found a better fuel pump assembly and started using those, but this new fuel pump assembly required two connections instead of one. I don't think this will cause a problem when you get your 5-speed swap.....but you just gotta get to Jeff's shop and i'm sure he'll break it down for you.
Old May 30, 2003 | 07:21 PM
Brandon90gxe's Avatar
it was probably just a newer design, becuase my buddies QX4 has 2 harnesses, and mine only has one.. we added another fuel pump on, i forgot but i think only one supplied the power.. the other may be sesors..
Old May 30, 2003 | 10:09 PM
Matt93SE's Avatar
STFU n00b!
how about ABS? which cars have ABS and which don't?
Old May 31, 2003 | 03:56 AM
N34JZ's Avatar
Needs non-Maxima Friends
the VE 5spd has no ABS and the auto does,
I only have one harness anyway Joe I could really use those trunk panels, before the meet.
Old May 31, 2003 | 11:35 AM
Maximan190's Avatar
maybe it does have something to do with abs.. but why would the fuel lines differ like that on abs vs non?
yea i just cleaned out the interior and im getting ready to part it out.. trunk is next ill clean it out and give you the panels when we go get the springs
Old May 31, 2003 | 12:54 PM
eric93SE's Avatar
I doubt there is anything else different other than the use of two harnesses. One harness is probably for the guage and the other is for pump power supply. Also note that the pump assembly is grounded (by one of those wires), to prevent any static discharge when the pump is being replaced.
Old May 31, 2003 | 06:07 PM
MrGone's Avatar
my 93 VE Auto only had one harness, the blue one. had everything except ABS. Maybe thats the difference? I dont know what your cars setups are though.
Old Jun 2, 2003 | 11:11 PM
shock211's Avatar
i actually checked my fuel pump a couple days ago...and it turns out that i have two harnesses as well.
i thought i only had one originally???
92 gxe auto
MattWithTheMaxima
Jun 30, 2017 01:06 PM
homeyclaus
Sep 3, 2015 06:15 PM
jerrod99_se-l
Aug 24, 2015 10:24 AM
KristyKarina
Aug 23, 2015 09:53 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
