Need help on my gauges
Ok, I've got two clusters, an SE and GXE cluster. I'm wanting to move the white face gauges onto my cluster. Do I just remove the needles and then the gauge faces will peel right off? How do I go about switching the gauges? Also, what bulb size is behind the gauges? Thanks
Re: Need help on my gauges
Swapping the faces sounds too hard and not likely to work right after you're done. Also even if you try to remove the faces, they must of been there like for 10 years and you might destroy them while trying to take them out.
hrmm i hear a write up coming from my head.
Pretty much simple thing to do.
The hardest part is taking out the cluster from the dash.
Now once you have taken the dash apart, disconnect the 4 wiring terminals from the back of the gauges. Now all you do is behind the location where the odometer is you take off the screws that are holding the fuel and temp guages. There is a wire that runs from the odometer to the back of the gauge, disconnect that. Separate the white plastic from the black plastic that are held in the middle. Do this carefully just press the tabs in and pull one side at a time. Once you removed the two bolts the odometer is prettey much a swap out from the original max odometer to the new white faced cluster. Make sure if you have the vg engine that you use the se vg white faced(89-91) 125 cluster.
http://www.angelfire.com/geek/vg30de...ix_Cluster.htm
220k+ A32
18
09-22-2015 11:39 AM
RWCreative
09-21-2015 11:01 AM
