R-134a retrofit
Old Jun 2, 2003 | 10:12 AM
CHM's Avatar
CHM
R-134a retrofit
I'm low on R-12 and am wondering about the durability and function of the factory system with R-134a instead of the original R-12? thanks
Old Jun 2, 2003 | 11:13 AM
jakew8's Avatar
Who?
http://groups.google.com/groups?q=r-...tex.net&rnum=2
Old Jun 2, 2003 | 08:06 PM
96ItaliaSE's Avatar
il massimi bassi
hi
i retrofitted my 1992 se cuz the lowside line had a leak in it. The 134a isnot as cold as the r12 but its still very acceptable. the compressor will get louder cuz its a thinner freon making it run at higher temps.
You are supposed to change o rings if you have a calsonic compressor. but i didnt and it works fine. My best advice if you maximas r12 ac is working but is slightly undercharged get a 100$ worth of r12 it will be much colder and more effiecient. You can use 134a , im using it now but if gived a choice id go back>
Old Jun 3, 2003 | 09:18 AM
CHM's Avatar
CHM
Thanks. I'm in the process of ordering r-12 now. That's what i thought.
Old Jun 3, 2003 | 09:25 AM
DanNY's Avatar
Ad·min·is·tra·tor
if it's just low and everything is working correctly then stay with R12
Old Jun 3, 2003 | 10:07 AM
93teg44444's Avatar
I'm new to this forum but I thought I should mention there is a company "autorefrigants.com" that sells an aftermarket replacement for r-12 that is better than r-134a, and arguably r-12. It's called es-12a. I recently ordered some for my Integra. I belong to another message board for Integras and alot of the guys over there use this stuff and love it.
Old Jun 3, 2003 | 10:56 AM
DanNY's Avatar
Ad·min·is·tra·tor
R12 replacement = autofrost
R134a replacement/better performer = cooltop
Old Jun 3, 2003 | 04:34 PM
rcy's Avatar
rcy
Also look at www.duracoolusa.com or www.duracool.com or http://www.amlautoservice.com/aircond.asp - read the last paragraph.
Duracool can replace r12 or r134a depending on the type you buy, but if you're in the states you're supposed to retrofit to r134a first (the fittings anyway) evac all the freon, then refill with Duracool or some such madness..check the EPA website. Personally, if I was low on freon, I'd just get a six ounce can (or two), a hose and top up my system - the Duracool can mix safely with Freon or r134. Just be aware that Duracool(and other HC (hydrocarbon) refridgerants) are banned in some states - I think. From what I can figure out, HC's are banned because they are just that hydrocarbons - like propane, and legislators are afraid of things blowing up. However, it appears that the stuff is no more flammable than freon or r134a. Who knows? All I know is I threw a can and a half into my system, and it's never blown so cold.
Maxima_Joe
Nov 25, 2015 08:19 AM
03VQMAX
Nov 10, 2015 03:39 PM
Vistance
Sep 17, 2015 05:17 AM
umnitza
Sep 1, 2015 01:03 PM
