cutting springs
Old Jun 2, 2003 | 04:59 PM
phast92se's Avatar
cutting springs
ok, before i get flamed for wantin to cut my factory springs, all i'm wantin to know is how hard is it to do?? b/c i'm thinkin bout cuttin them to get about a 3" or more drop, jus for local shows, NOT FOR DAILY DRIVING!!! any help is appreciated
Old Jun 2, 2003 | 05:26 PM
Walka's Avatar
first of all, not wise.
second of all, isnt that a lot of labor to swap springs back and forth for shows.
my advice, do it right or dont do it at all. your max is a daily driver right? dont put the utility of the car at risk.
walka
Old Jun 2, 2003 | 05:38 PM
phast92se's Avatar
its not really a whole lot of labor, i put my sprints on in about 3 hrs, and that was wit the help of jus one friend, and one spring at a time... but anyways i was jus thinkin about it, i'm not all that sure im goin to do it
Old Jun 2, 2003 | 05:59 PM
KLoWnPR109's Avatar
I've got some cut front springs I could sell you if you are deadset on doing this
Old Jun 2, 2003 | 09:57 PM
Matt93SE's Avatar
STFU n00b!
just get coilovers. it'll save you lots of headaches later.
Old Jun 2, 2003 | 10:35 PM
phast92se's Avatar
coilovers??? i remember when there was gd to get some... nobody, including myself, had the money to get them
Old Jun 2, 2003 | 11:00 PM
aw89maxSE's Avatar
Coilovers for 3rd Gens, I thought they were none exsistent??
Old Jun 2, 2003 | 11:17 PM
Kennedy's Avatar
I put my springs on in 20 minutes once I realized how stupid I was.
Disconnect the torsion bar (21mm Socket) the whole assemply drops down. I didn;t even use compressors, instead I used a second jack to compress the spring enough to the get the bolt and spacer on. After that, I dropped the second and first jacks and used the cars weight as a natural compressor to put the torsion bar back on for those new racing springs.
Old Jun 3, 2003 | 07:28 PM
phast92se's Avatar
what????? i dont wanna sound like an a$$ but duh! thats what your sposed to do to put new springs on
Old Jun 3, 2003 | 07:53 PM
MaximaBalla's Avatar
Old Jun 4, 2003 | 02:19 PM
shavedmax's Avatar
ummmmmmmmmm, no. the "way" to do it is to compress the spring with a spring compressor, put the assembly together and bolt it up. that doesnt mean that what he did isnt an acceptable method without the proper tools, just not the "best" way.
before you cut up springs, why not try to clamp them down. its like 6 bucks for a set for each wheel, it takes a turn off yor spring and if you dont like it, you just take it off, not have to replace a set of springs
Old Jun 4, 2003 | 06:52 PM
Kennedy's Avatar
I would have done it using compressors, except these springs were far to sturdy for them and kept exploding out of the little lip thing. Almost took my face off once.
Easier, more simplisitic way for sure. I ended up needing an impact wrench, and a new socket set. But hey, aslong as you get em on... WHatever works.
Old Jun 5, 2003 | 12:11 PM
phast92se's Avatar
where can i get these clamps and is there a specific name to ask for when i go to get them??
Old Jun 5, 2003 | 12:14 PM
phast92se's Avatar
Kennedy, i think i just read your post wrong, i get what you were sayin now. when i put my sprints on, i didnt have a compressor either i used to straps and tightened the straps to the springs before i took it all apart. i stood on the new spring and tightened it up wit the straps when i put everything back together.
Old Jun 7, 2003 | 10:44 AM
shavedmax's Avatar
i replied ti your pm, but they are actual spring clamps, usually in the suspension/exhaust/air tool section of autozone. its used to lowersprings or extend springs, depending on how you use it.
Old Jun 7, 2003 | 11:55 AM
phast92se's Avatar
oh ok... i might check that out then... you wouldnt happen to know how much they lower the spring??
Old Jun 8, 2003 | 07:27 AM
shavedmax's Avatar
depends on the spring, usually an inch to two
Old Jun 8, 2003 | 10:06 PM
phast92se's Avatar
hmmmm... i wonder how much it would drop me wit my sprints... my front wheels will prolly rub
Old Jun 9, 2003 | 12:08 AM
kingrye's Avatar
what does rubbing sound like when i turn there is a soft skeewking sound with my intrax spring, i think it might be the strut making the noise thou
Old Jun 9, 2003 | 12:10 AM
phast92se's Avatar
i dont even know... my tires have never rubbed before
Old Jun 10, 2003 | 06:29 PM
stilesmax's Avatar
I have sprint springs and they say that it lowers the car 1.8" but when i measured my car to Bijan's stock max it was about 2.25". I think that is low enough. I occasionally bottom out on speed bumps and driveways, but with the right angle I hardly ever bottom out.
Old Jun 10, 2003 | 09:48 PM
phast92se's Avatar
i only wanna drop my car when i go to local shows and stuff... cuz i bottom out on damn subdivision curbs enough as it is now... i like the way it looks now without the spring compressors
Old Jun 10, 2003 | 10:43 PM
mtcookson's Avatar
you can cut springs, you just have to know what you are doing. before you cut the spring you have to get the spot where you are going to cut it hot enough to bend. once you get it to where you can bend it you have to bend it to where it will seat the strut where the little lip thing is. if you take you spring off and look at it you'll see how there is a bent spot that seat perfectly on a spot on the strut. bend the spring to fit in that spot correctly and you shouldn't have very bad camber problems. be sure to not take too much of the coils off. my friend wanted a 1 to 1.5 inch drop. they measured the coils and cut two coils off.... they ended up with a 5 inch drop on a 86 Corolla GT-S. there is a book for chassis engineering that shows how to cut springs. i think borders has it.
Old Jun 10, 2003 | 11:42 PM
nubiannupe's Avatar
OG Maxima.org Member
I thought I was crazy when I measured my sprints and saw an almost 2.5 inch drop. Guess I wasn't...
magiconthetire
Oct 26, 2015 09:03 PM
MaxLvr21
Oct 17, 2015 12:11 PM
RealityCheck
Oct 2, 2015 06:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
