almost had a dyno
Old Jun 5, 2003 | 04:14 AM
4signs's Avatar
almost had a dyno
I was suppose to goto the dyno today but my tranny stuck in 2nd gear. (I already broke an axle)im pretty sure im putting out over 300hp at the wheels,(my butt dyno say 425whp, take away 125hp for parasatass loss = about 300hp) but I guess im going to have to wait until next month to get true dyno #s. My new turbo came in yesterday(t3/t4)I wanted to run the t4 on the dyno but I also blew a seal, so hopefully next month we can see what a ve equiped with a t3/t4 can do.
Old Jun 5, 2003 | 07:54 AM
Matt93SE's Avatar
STFU n00b!
sounds good... now keep your foot out of it until you get it on the dyno and tuned!
one thing about FWD cars.... with that much power, you MUST be nice to them or you'll be replacing parts all the time. you may have a ton of power, but the car isn't designed to handle it. you'll snap axles and ruin wheel bearings and blow trannys left and right if you beat on it all the time.
Old Jun 11, 2003 | 09:12 PM
shoult's Avatar
Re: almost had a dyno
So you've taken a 190 hp (really about 155-165 fwhp) engine and bolted a turbo on it and now it's 425 fwhp or even 300? Unless you've done some other serious mods to support a turbo at 15-20 psi or so you're not even going to be close to 300 fwhp.
What other mods do you have? How are you dealing with super high compression ratios (static compression + boost)? What fuels are you using? What size fuel injectors are you using? What fuel pressure regulator? What size fuel line did you use? Dished pistons? Thicker head gaskets? What are you doing to cool the intake charge? A2A or A2W intercooler? Water Injection? 50% Methanol injection? What are you doing for engine management?
In my experience you don't just throw a turbo on an engine and double it's hp. It just doesn't happen. Or it doesn't happen for long.
Old Jun 11, 2003 | 09:45 PM
4signs's Avatar
Re: Re: almost had a dyno
Old Jun 11, 2003 | 09:47 PM
4signs's Avatar
turbomaxima.com.......its been done, just waiting for the dyno to tune it
Old Jun 11, 2003 | 09:51 PM
4signs's Avatar
425fhp was exaggerated humor (butt dyno)
Old Jun 11, 2003 | 10:03 PM
phast92se's Avatar
i took a look at the pics on turbomaxima.com, but which VE max is yours??? either way, under the hood looks extreeeeemely crowded
shoult's Avatar
I see the claims of 100 fwhp @ 4psi and a ton at higher psi values and the claim that it's on stock internals. My experience tells me that the 4 psi version will live, but is not going to give 100 fwhp. It's more likely going to be in the neigborhood 40-50 fwhp.
I also going to believe that 11 psi won't live long on stock internals. To much compression, to little fuel.
I'd be happy to see some dyno charts to prove me wrong about the first, but even a dyno won't convince me that that engine will live long at 11 psi without some modifications to support it.
Old Jun 11, 2003 | 10:05 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
theres only one on there
Old Jun 11, 2003 | 10:07 PM
Jeff92se's Avatar
I'm needing a caw
Actually fuel and timing is not a problem w/ 3-gens. JWT can fix both even with bigger injectors, maf,tb etc.. or you can turn back the base timing and band aid it with a SARD. Like I plan to.
Old Jun 11, 2003 | 10:13 PM
phast92se's Avatar
my bad... i looked at it again, for some odd reason i thought there was two... my fault
Old Jun 11, 2003 | 10:14 PM
DA-MAX's Avatar
being that there are no other turbo VEs to compare, you'll have to use the similar VQ motor...although the end performance between TCs and SCs differ on these cars(with turbo having a higher output at equal psi)there are numerous supercharged VQs running 10-11 psi on stock internals with stock injectors for years now, no one has reported adverse affects...like I said in the other supercharger post the FMU/high flow pump combo has proved to be the ultimate factor in tuning these high CR Maxima motors and is more than enough to support these PSI amounts on the stock equipment...I mean some of these guys are making excess of 325fwhp on the stock block, no IC or aquamist, no bigger injectors, its VERY possible!
Old Jun 11, 2003 | 10:16 PM
DA-MAX's Avatar
there are 2 third gens but only one VE
Old Jun 11, 2003 | 10:27 PM
phast92se's Avatar
yeah i forgot that MAX O/D has a VG... thats why i thought there was two on there
Old Jun 11, 2003 | 10:39 PM
AscendantMax's Avatar
man...this thread makes me wanna get a VE even more
Old Jun 11, 2003 | 11:38 PM
4signs's Avatar
took the words right out of my mouth
Old Jun 12, 2003 | 12:06 AM
MaDMaX024's Avatar
at a crossroads...
how reliable is a turbo setup on a VE pushing like 6psi, intercooled, 370cc twin turbo Z injectors? i know its been done twice that we know of, so 4signs, how reliable is your setup? can anyone else speculate?
Old Jun 12, 2003 | 12:13 AM
adamis's Avatar
Hah, hah, you can have a thousand horsepower but it ain't gonna do you any good if you keep breaking stuff. Course if you got this far I'm sure you'l figure out how to get that power to the asphalt without blowing through to much cash. Kudo's for pushing the limits. Just out of curiosity, did you do anything to your tranny or is it stock?
Old Jun 12, 2003 | 03:37 AM
4signs's Avatar
Originally posted by MaDMaX024
at a crossroads...
I have been running 5-6psi intercooled for the last few months, on a couple of cold days I cranked the boost to 8-9(broke an axle), had a kink in my oil return line and blew the seal out of the turbo, still using the stock injectors, im running on the rich side,(8:1 fmu)but I dont think im maxing out the injectors a 6psi. (I need a fuel press gauge) So far the motor has been running strong.
Old Jun 12, 2003 | 03:53 AM
4signs's Avatar
Im running a lightweight flywheel and act clutch. I replace the bearings and rebuilt the tranny while doing the turbo project. I was press for time (moving and had to ship the car)and I forgot to put the gear shaft ball/spring in the tranny, so 3 out 10x I put the car in reverse the shaft would move and engage 2nd gear while set in the neutral postion.(i can't put it in reverse,1st,or slide it in 2nd postion, and it wont engage the reverse gear) I would have to wiggle the shifter side to side until I can knock the gear out of 2nd into neutral, then It usaully slip into reverse normally. I know this sound weird and confusing, the other day I tried to put it in reverse and it got stuck again, this time no matter how much I wiggled the gear stayed stuck in 2nd while in neutral. Im in the process of pulling the tranny out to disengage the gear and put the spring/ball back in. Moral of the story...take your time!
Old Jun 12, 2003 | 06:47 AM
Matt93SE's Avatar
STFU n00b!
hmm,m it only takes 4 hours to pull and replace the tranny... that's only a day's worth of work to rip it open and fix it.. sounds like it's worth it to me instead of potentially tearing it apart because you're putting things off..
Old Jun 12, 2003 | 07:18 AM
shoult's Avatar
8:1 and you only call that rich? I sweated the details when I was running 11 and 12:1. Yeah, it's better to be rich then lean, but you're drowning. You need some fuel management......
Old Jun 12, 2003 | 07:23 AM
Matt93SE's Avatar
STFU n00b!
sure thing.. lemme call up JWT and have them deliver a proper ECU right to him... HA!
you have any viable sources on where to obsain said fuel managament, without spending $2000 on a Motec, or simply buying another band-aid ECU piggyback?
Old Jun 12, 2003 | 08:19 AM
DA-MAX's Avatar
slow down and re-read it dude. your missing the point...he is using fuel management, he is using the Vortech FMU with an 8:1 disc(thats 8lb increase in FP for every llb increase in boost pressure). he's not talking about A/F ratios...
Old Jun 12, 2003 | 09:11 AM
Nismo87SE's Avatar
IMHO the cheapest/best way for a VE turbo fuel management is with a Z32TT ECU. I've compared the wiring harnesses and they match up the only difference is that the fuel pump relay is slightly different and you won't have any boost control soleniods. Otherwise you can swap in the turbo ECU + MAF/injectors and it "should" run like it came from the factory with a turbo. However the powervalve might not work but you'd probably want to tie that open anyway with boost!
subs1000w's Avatar
thats funny that yours got stuck in second to because thats what happened to mine back in december and we rebiult the tranny and put it back to gether and when bench testing it still got stuck in second so we just streched out the springs that put pressure on the ***** and all is well for about 6 monthes and counting
Old Jun 12, 2003 | 09:16 AM
Jeff92se's Avatar
I'm needing a caw
woah
Old Jun 12, 2003 | 02:55 PM
4signs's Avatar
so true but I just got my tools from hawaii, a week and half ago, and Im either working or its raining outside
Old Jun 12, 2003 | 03:45 PM
4signs's Avatar
I was wondering about that a few weeks ago, thanks for the info, now all I need is ecu and the maf
( I was going to use a piggy back, but ill try that first)
Old Jun 12, 2003 | 04:01 PM
Nismo87SE's Avatar
I remember Bryan H saying that he used a Z32 ECU in his max so I got the wiring diagrams and looked them up. Sure enough the NA ECUs are plug and play. The difference between the VE ECU and the DETT ECU is there aren't any boost control soleniods and the fuel pump relay has an extra wire. So if one could get the ECU + injectors/MAF (assuming the Z32 maf is different from maxima) then the car should run fine. TT ecu = boost friendly timing/fuel trim curves and a 7000rpm rev limiter (VE is 6500rpm). Now given a nice size T3/TO4E turbo with the VE's 10.1cr it should make more power per psi than a DETT should.
Old Jun 12, 2003 | 05:32 PM
4signs's Avatar
you are the man!
Old Jun 15, 2003 | 11:05 AM
Maximamike's Avatar
Wanna meet up sometime? My cars messed up so maybe I can score the 2k GLE for a lil while. I can video/take pics at the dyno if you want. Where are you going to dyno? If we meet up I'll see if I can grab a VG30DETT ecu from a friend to bring since his car is off the road for a lil while. Email me/AIM me/PM me. Thanks bro..
Old Jun 15, 2003 | 12:52 PM
4signs's Avatar
you got mail
Old Jun 15, 2003 | 01:07 PM
CandiMan's Avatar
Say Candyman 5 times
Originally posted by Maximamike Wanna meet up sometime? My cars messed up so maybe I can score the 2k GLE for a lil while. I can video/take pics at the dyno if you want. Where are you going to dyno? If we meet up I'll see if I can grab a VG30DETT ecu from a friend to bring since his car is off the road for a lil while. Email me/AIM me/PM me. Thanks bro..
For real, especially that VG30DETT ECU part
Old Jun 15, 2003 | 04:54 PM
Maximamike's Avatar
you got mail
Which email addy? If it bounces back try mjcnismo@hotmail.com. Thanks mang!
Ben2003GLE
31
Jul 17, 2016 08:13 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Chebosto
Dec 19, 2001 06:34 AM
Nismo87SE
Oct 23, 2000 08:15 AM
