Need Help With Shock Sensor Installation
Old Jun 9, 2003 | 09:02 AM
Nissan-R's Avatar
This weekend, I tried to install a single stage shock sensor into my factory alarm. I wired the negative wire from the sensor into a wire that only gets negative when the alarm is arm. The color is green with red stripe. The sensor's (+) into constant 12 volts. And the sensor's trigger wire into a wire that sets off the alarm, which is a gray with black stripe.
When i hit the car, the sensor does send a signal to the alarm but it doesn't set it off. This is the weird part. If I use a multi meter and set it to "batt", then touch the gray wire/black stripe with the positive lead and ground the other lead, the alarm is set off.
How can I use a relay to make this work? Or is there another way to make this work.
Thaks, Jason.
rbuswell
Nov 12, 2016 04:11 PM
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
