weird noise
Old Jun 9, 2003 | 02:01 PM
snowman2155's Avatar
weird noise
I changed my cv boots over the weekend on my 92 Maxima SE. Everything was cool, but when I drove around the block after getting it back together, I noticed a weird noise from the passenger wheel(the side I worked on). It's kinda like a wind noise at my wheel-if that makes any sense. It doesn't sound like brakes or rotors. Any suggestions of what it might be would be greatly appreciated. Thanks guys.
Old Jun 9, 2003 | 02:25 PM
chrispy's Avatar
grinding maybe? roaring? possibly?
maybe wheel bearings? or the ball joint?
Chris
Old Jun 9, 2003 | 02:36 PM
It's not a grinding noise. Maybe a light roaring noise. I was thinking that it could possibly be wheel bearings, but I didn't mess with those. Thanks for the reply.
Old Jun 9, 2003 | 02:41 PM
DanNY's Avatar
Ad·min·is·tra·tor
it sounds like wheel bearings. does the noise get louder as u go faster?
if yes then did u torque the axle nut correctly? did u put the big washer back on behind the nut?
Old Jun 9, 2003 | 02:56 PM
CandiMan's Avatar
Say Candyman 5 times
When you had the shaft out of the hub, I guess you didn't rotate the wheel bearing by hand to check it's condition and check the ball joint condition. Is it possible you could have bent the rotor backing plate causing it to rub on the rotor. Since you chnaged the boot that mean you had to seperate the axle bearing, did you push the axle bearing completely back on. Along with the noise being louder when going faster, does the noise go away when making right turns. Just giving you different possibilities.
Old Jun 9, 2003 | 02:57 PM
You know what, the torque specs for the hub nut is 174-231 ft-lbs. My torque wrench that I have only goes to 150. Do you think that's what it could be? Thanks
Old Jun 9, 2003 | 03:05 PM
CandiMan's Avatar
Originally posted by snowman2155 You know what, the torque specs for the hub nut is 174-231 ft-lbs. My torque wrench that I have only goes to 150. Do you think that's what it could be? Thanks
Only one way to find out, and you don't even have to remove the wheel. How lucky
Old Jun 9, 2003 | 03:22 PM
The noise only comes when I'm going straight, not when I turn. You think the wheel bearing didn't get pushed on tight enough by the hub nut?
Old Jun 9, 2003 | 04:09 PM
chrispy's Avatar
when my wheel bearings were goin bad, they did that, it made no noise on left turn, alot on right turn, and some going straight
it may be your bearings making noise, even if they arnt bad
Chris
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
