Car Will Not Turn Off
My car will not stop turning when I turn the key to shut down the engine. The only way to make it stop is by stalling it (releasing the clutch). But even then the accessory lights still stay on. I have to disconnect the battery terminals to keep the battery from draining. We have checked the ignition switch and it appears to be ok. Has anyone else come across something like this? All help appreciated. David
I have a neighbor who is a pretty good mechanic helping me on this and he is stumped. He said that he "thinks something is keeping a certain relay energized" and that perhaps "some type of module/solid state device is shorted out.".........Is there anywhere online where a wiring diagram for a 91 maxima se can be found? The Haynes manual does not have a whole lot of information. David
I'm also thinking its a bad relay. Well there are a couple ignition realys under the hood that are labeled in those two locations. There are also two relays under the left drivers side kick panel, I'm pretty sure they're for the ignition system (blue relays).
So what you can do is either give them a few good hits with something wooden or plastic. do them one at a time when trying to turn off the car.
And if its not a relay, then it would have something to do with the ignition where you insert the key. You can spray some wd-40 in their (wont hurt anything) but its probably not the problem.
Try disconnecting your ignition switch. If this shuts everything down, you have located the short. remove the kick panel under the steering wheel. locate the harness that connects to ignition lock. The connector rectangular in shape. Give that a try. If that doesn't work then I have more questions. do you notice if anything shuts down when you turn off the key? Do you have any aftermarket electrical equipment in the car (alarm, remote start, radio). I hope this helps. If not I can give you mre info when I have my reference with me.
The ignition switch/housing was taken apart but evidently it was ok. Neighbor did the diagnostics on it and said it was ok. When I turn the key all the way off the accessories (radio, etc.) do go off and the idle bumps down a little bit.;...but the engine keeps running.
Looking at the wiring diagrams for both engine types, power for the ignition system is supplied ultimately from terminal 3 or the white w/ green tracer wire on the ignition switch connector. If your buddy is correct in his diagnosis and disconnecting the ignition switch harness connector does not shut down your engine than that before mentioned wire is getting power from somewhere else. You can try pulling your fusable links one by one to see if you can get you car to shut down.
Its a 91se 5 speed. The only 2 things that have caused all electrical connections to cease is pulling the radiator fan fuse, and pulling the eccs(green) relay up by the battery. If there were a problem with a transistor in the ecu, would the ecu flash a code? Thanks, David.
Okay, looks like you've found something. Pulling the radiator Fuse Link should not have shut down your car. That circuit is independent of any engine component. Try this, with the car running and the key in the off positions. Pull each radiator relay on at a time. If your car shuts off with one of the relays, leave that one out and put the rest in. Now repeat; start the car and turn the key off. If this is the case what color is that relay?
pulled the radiator fan connectors and the car kept running. i dont have the diagram in front of me but if memory serves the radiator fan fuse also affects/covers several other electrical operations in the car. David
Originally posted by dsantos
I would like to also clarify. What color was the radiator fan fuse link?
This does clarify. This powers the low amp side of all the rad relays, the air conditioner relay and Climate control door controls and relay. Still these circuits should not affect engine running. I am at a loss. I know you cover this before, did you ever try to disconnect the ignition lock connector that is mounted on the streering wheel pivot point under the dash?
My reference that I have been using is a chiltons manual. They seem to be the same diagrams that are used in the official service manual. Unfortunetly I will not get a copy of my service manual manual till next week.
Any way. You say that fuse inside the car shuts the engine down. Try the rad fan fuseable link next to the battery. Should be a red fuse(45a) next to your main fuseable link.
Okay, first of all, do you know about Chilton's online manual?
It can be useful in your situation.
Second, I have Haynes manual for Nissan Maxima 1985-1991 and I can scan some diagrams from there. Do you need it?
Neighbor worked on the car some more today. Found a problem with the 'meter' fuse, 6th from the bottom on the left side. Pulled fuse and car will turn off properly with fuse pulled, and yet all functions tied into the fuse still work. Thinks that there is a short/ground/problem somewhere between the fuse and the ecu, probably within the ecu. At a loss because of no wiring diagrams. I have a Haynes manual but it does not have the diagrams needed. Tried Chiltons online but was unable to access their diagrams. If anyone has access to a diagram linking the ecu and the fuse box it would help alot. thanks, David.
I dont know exactly, but its around $500. Buy it from www.courtesyparts.com ask for the internet discount (or maxima.org).
Originally posted by dw40
If I was to find one from a junk yark or on the classifieds board would it matter if it was a non se, and would a 1992 plus ecu work in a 91? Thanks, David.
Any ecu replacement would have to have: the same engine, same tranny, and emissions standard (federal/cali).
Lakersallday24
Jun 16, 2019 01:35 AM
kirkhilles
Aug 8, 2015 10:53 AM
