Adding sensor to Factory Alarm 3RD GEN.
Has anyone added a sensor successfully to your 3rd. gen Maxima? There's a nice write up for it over at VQpower.com but it's for a 4th gen. I've got a 92auto and don't know where exactly to find the 3 needed wires. There's a box right above the ECU, that I suspect is where they are, but am not sure.
-R92max
-R92max
Originally posted by Matt93SE
do a little searching on it. I believe there's some info on craig B's page, and I know NGthing (oohhhh... never wanted to hear that name again!) put a shock sensor or something on his alarm.
Two weekends ago, I wired a one-stage shock sensor. The sensor has three wires, positive, ground, and trigger. Wire the positive from the sensor into constant 12-volts, red wire, located in the steering column. The ground wire can be grounded to chassis ground. Make sure you use a good ground. Next, wire the trigger wire from the sensor to a gray wire/black stripe coming from the theft module, located under the steering column. This gray/black wire is the trigger for the factory alarm. The box is marked "THEFT MODULE". You will need to remove the lower panel to access the alarm brain--THEFT MODULE.
The sensor will be on the entire time. It's is not a problem. The gray wire/black stripe coming from the factory alarm is only active when the alarm is armed, so if the shock sensor sends a signal, it will get triggered. On the other hand, if the alarm is disarmed and receives a signal from the shock sensor, it will not respond, since the gray/black wire is inactive.
If you buy a two-stage shock sensor, the only additional step you need to take is to wire the pre-warm wire from the sensor to the horn wire, which is a brown wire/white stripe also located in the steering column.
Craig had a post a while ago regarding this. In his post, he recommends grounding the ground wire from the sensor to a green wire/red stripe from the alarm brain. This wire only gets ground when the alarm is armed. The ground this green wire/red stripe provides is not sufficient to trigger the alarm. I tried it but it did not work.
I hope this helps; let me know if you have questions.
Jason.
Jason.
Thanks Nissan-R and fattamax for the info. I finally located that sucker. I tried searching on this forum, but it never seems to work. The way the write up was on VQpower, VQwriteup, I think the guy has it so that the sensor only gets power when the alarm is armed. But I guess that the sensor doesn't draw much power or cause any problems. This car just really needs a full aftermarket alarm w/ keyless. I'll have to give this setup a try though.
Thanks,
-R92max
Thanks,
-R92max
MAXSE5SPD
Sep 17, 2022 04:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
