Squishy front end plus clunking
Old Jun 18, 2003 | 05:05 AM
96ItaliaSE's Avatar
il massimi bassi
hi,
the max has squishy front suspension. The front struts and ball joints are new ( withinh 6 Mo.). The tie rode ends are old yet are not loose at all. I jack the wheel up and shake it up and down and side to side no looseness. The Passender tire is wearing uneven got an alignment 6 months ago with new tires.
bushings are original and are not cracked. I wanna pinpoint the problem.
92 se 160k
Old Jun 18, 2003 | 07:11 AM
jakew8's Avatar
Who?
did you replace the springs when you replaced the struts?
Old Jun 18, 2003 | 08:17 AM
96ItaliaSE's Avatar
il massimi bassi
thats a negative jake.... funny the front end came up about 1.5" when i put new struts in. I figured it would handle better with new strts but its much worse. Bounce bounce bounce!! I replaced the stuts only a few weeks ago.(KYB GR2) I even ponder sometimes cutting a coil off the front springs....there is NO way it can ride any worse than it is now
PS I already replaced the rear struts as well
Old Jun 18, 2003 | 11:37 AM
Matt93SE's Avatar
STFU n00b!
1. you should ahve gotten better struts. the KYB are crap.
2. look at your control arm bushings. with that kind of mileage, I'll bet they're gone. that'll cause the car to wander on the highway and dart different directions in corners.
Old Jun 18, 2003 | 01:19 PM
96ItaliaSE's Avatar
il massimi bassi
yah they def are not new. Do u have any crossed referenced urethane bushing #'s for the control arm, sway bar or endlink? what size are they maybe i can get a universal
96ItaliaSE's Avatar
il massimi bassi
Old Jun 18, 2003 | 05:26 PM
cmuehlenb's Avatar
My max had the same problem. It is the front bushing on the passenger control arm. It is not easy to see that it is worn because there is a giant flat washer behind the nut. You can tell its this if the steering wheel shifts to the right under hard acceleration. Also, you can check it by jacking up the car and pulling on the control arm with a pry bar. The bushings are integral to the arm. So, you have to replace to whole control arm ($180 new, $80 from a junk yard). It takes only about an hour to replace. There are procedures around to buy older generation bushings and press them on. But, it sounds like a pain. Just get another control arm.
Old Jun 18, 2003 | 05:47 PM
Gjohnson's Avatar
My car had this problem (pretty severe too!) but you don't have to replace the whole control arm, just the bushings. PM Matt93SE above, he replaced mine and has a real good deal going. Thanx Matt.
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
GregL65
Sep 5, 2015 09:37 PM
jfl330
Sep 4, 2015 01:44 PM
