brakes
Old Jun 18, 2003 | 10:32 AM
FOR93MAX's Avatar
brakes
Just got my first Max 93 GXE luxury package perfect condition paid $7000.00 Canadian. Thats about $5400.00 US.
I think that is a good deal considering the quality of Nissan products.
Anyway, Ihave done a front brake job and I did not Machine the rotors. They look to be in excellent condition. However after using all the anti squeal products the brakes still squeal and I get vibration at higher speeds (ie: 140klm or 85mph plus)
If the rotors are slightly out of round could that cause the squeal and or the vibration I am experiencing?
Old Jun 18, 2003 | 11:34 AM
Matt93SE's Avatar
STFU n00b!
it'll cause the vibrations, definitely. remove the rotors and have them turned/machined. most parts stores can do this in about an hour for $5-10 each.
when you do that, sand the surface of the pads across the direction of the rotor with 60 or 100 grit sandpaper to remove any grooves that have developed in the pads.
that should help with the squeal also, but you never know. the GXEs here in the states have drums brakes in the back and they're usually the cause of the squeal. I know some GXEs up there have disc brakes, so I can't comment on that until I know drums or discs in the back.
Old Jun 18, 2003 | 03:59 PM
FOR93MAX's Avatar
Thanks, I'll do that this week end. Rear disks as well but for sure the squeal is from the front.
Old Jun 23, 2003 | 10:19 AM
FOR93MAX's Avatar
Well I bought new front rotors installed them and the vibration stopped for the most part, but after one hard braking at hyw speed the brakes started to drag again and the squeal was back???? Could the back rotors have warped that easily being that they are old??
Old Jun 23, 2003 | 08:57 PM
93teg44444's Avatar
did you put shims on the brake pad when you insalled them or is the anti-squeel product you talk about the gel stuff. Also what type of pads are they. some of the more metallic pads tend to squeel. Since there is metal in the pads you get a metal on metal squeel.
Old Jun 24, 2003 | 08:18 AM
Matt93SE's Avatar
STFU n00b!
did you properly break in the rotors and pads? you can't just run them up to 100 and stomp on the brakes.. you'll ruin them almost immediately.
Old Jun 24, 2003 | 04:03 PM
FOR93MAX's Avatar
No, I drove normally. but I looked again at the back brakes and it looks like the there is some drag there. So the only thing I can think of is the origional owner did not use the emergency brake and when I started using it, it jammed up and now won't release properly.
Or the rear caliper is screwed. I wish I had more experience at this but I guess I will have by the time I finish this.
Can the emergency brake cable (spring assembly) on the caliper be fixed without replacing the caliper or the cable??
Old Jun 24, 2003 | 04:06 PM
Jeff92se's Avatar
I'm needing a caw
yeah you can take off those items w/o removing the calipers.
Old Jun 25, 2003 | 12:34 PM
FOR93MAX's Avatar
I feel a little like a fool but it's not the emergency brake and calipers are ok, the pads were jammed up with corosion and couldn't release after the caliper compressed. I cleaned it all out works ok but I think new pads and machined rotors will be going on this week end.
Thanks for all the advice it sure helps us newbies
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
