Hearing a clunking.....
Old Jun 22, 2003 | 08:41 AM
99SEL4ME's Avatar
Hi, guys, I'm hearing a clunking while turning, but only when going slow, like pulling out of my driveway. Is it the cv joints, or axles?
Thanks for any input.
Jeff
Old Jun 22, 2003 | 10:01 AM
Torres's Avatar
Re: Hearing a clunking.....
Jeff
this happened 2 me 2....try checkin' the power steering fuild level....mine was down 2 just a drop and it was clunkin' when i turned........
Old Jun 22, 2003 | 02:03 PM
99SEL4ME's Avatar
Re: Re: Hearing a clunking.....
Nope, not the power steering fluid, just checked it. It's full.
Old Jun 22, 2003 | 02:33 PM
ChrisCheezer's Avatar
Re: Re: Re: Hearing a clunking.....
check ur CV boots
get under the car and fidn the axel.. the CV joint.. and boot connects to the wheels hub, see if they are torn up.. if soo get new boots... unless they click alot when u turn.. then u need new axles
Old Jun 23, 2003 | 01:17 AM
ghostmax's Avatar
Jeff
might be spring related, a bearing or missing the rubber end.
Old Jun 24, 2003 | 09:18 AM
Cincy94Max's Avatar
Clicking is CV related most of the time. Clunking, which I just had happen to me is axle related. Axle's dry out and need to be replaced. My axle noise was just as you described.
Old Jun 24, 2003 | 10:44 AM
alane's Avatar
my front passenger control arm bearing was...NON-EXISTENT! this caused major clunking when going over bumps and turning hard, particularly pulling out of my drive way...I also believe it to be the root of my steering prob where the steering wheel would change position while I was driving...check your control arms...
~andrew
Old Jun 25, 2003 | 08:13 AM
DaBoxSE's Avatar
I'm hearing a clunking in the rear. I hear it especially when I go over a speed bump. I think it might be something with the either the struts or mounts...Im not too worried though because Im putting the Tokico's in soon
How is everything else with the car Jeff?
By the way: Meet this sunday check the NE forum
Old Jun 25, 2003 | 11:12 AM
ghostmax's Avatar
my clunking happened in the fronts when i went over bumps. when i changed my springs and struts last weekend, i lubed the upper strut bearing. i don't know if the grease helped or changing the struts. nissan dealer told me it was probably worn strut mounts (about 70.00 at the dealer, no thank you). i didn't replace them. there's a write-up at www.motorvate.ca.
Old Jun 25, 2003 | 12:11 PM
DaBoxSE's Avatar
If your strut mounts are worn then you probably should have replaced them. Eventually they will wear out even more and you will have to change them by removing everything again. You can get KYB strut mounts at www.taylorautomotive.com for about $36 each.
Old Jun 25, 2003 | 12:36 PM
Gjohnson's Avatar
When I bought my car the first thing I had fixed was the strut mount on the passenger front. I would get a horrible clunking noise also, but afterward I would still hear some slight noises until I changed my lower control arm bushings.
Old Jun 25, 2003 | 01:28 PM
PuMa's Avatar
This just happened to me i had a bad cv boot and bad struts.
Old Jun 25, 2003 | 01:48 PM
ta90maxz's Avatar
it could be your control-arm bushing,have a good mechanic check your front end out.
90MAX:/KYB'S, K&N cone,300ZX STEERING WHEELS,98MAX RIMS, more to come.
Old Jun 25, 2003 | 03:28 PM
Life2daMax's Avatar
Here it is
I am currently going throught the same prob, i took my car to my favorite mechanic, and he said my wheel axle is bad. Getting it replaced, costs about $130 parts and labor. Hope this helps, after all this is my frist post...
tarun900
19
Dec 20, 2021 06:57 PM
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
