lost user manual - need help resetting factory alarm
Old Jun 22, 2003 | 05:15 PM
petenice00's Avatar
got an 89 gxe with the touchpad security system. do i need to reset it after it has been broken into? i want to reset it to be sure that is not the reason the car is not starting (i doubt it but it's a quick process of elimination).
PK
Old Jun 23, 2003 | 07:53 AM
Ixiterra's Avatar
It is a very simple anti-theft system. It is disengaged once you either type in the entry code or unlock the door with the key.
If you need to reset the entry code, you need the master code which should be on the original keyring. When you type that code in, it will make a very long beep in which time you can enter a new entry code.
Old Jun 24, 2003 | 08:56 PM
petenice00's Avatar
where else in the car would i find the original master code and can you give me the exact keypad sequence i would be required to enter in order to reset/change the code....i lost my manual....thanks for your help in advance.
pete
Old Jun 25, 2003 | 02:25 PM
davecmu's Avatar
Link for more info
Key Code Reset Info
Because it's such a touchy subject (people pretending to have "lost" their codes, etc., we've created this form to allow you to generate the process for resetting the code.
Enter the requested information (none of it is confidential, so don't worry about internet security) and let the computer do the rest.
Good luck!
Old Jun 26, 2003 | 12:07 AM
crazy4maxima's Avatar
do a search and you see my write up i have written in many threads. search for write up keyless entry and you will find my posts
Old Jun 26, 2003 | 07:15 PM
petenice00's Avatar
thanks....will do...
MAXSE5SPD
Sep 17, 2022 04:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
