Headlight harness
Old Jun 23, 2003 | 04:47 PM
Tom91GXE's Avatar
Headlight harness
One of my headlight wiring harness' just went out from my xenons. anyone know a cheap good place to purchase these?
Old Jun 23, 2003 | 05:01 PM
CandiMan's Avatar
Say Candyman 5 times
Local parts store, a new headlight harness for a 9004 bulb isn't anything that's new or top secret. Most parts store will carry new harness. I pick up a two harness fom PepBoys for $5 a piece. Check my homepage for pics of "my" new harness. After purchasing the new harness I changed the gauge of the wire to a larger gauge.
Old Jun 23, 2003 | 09:01 PM
93teg44444's Avatar
it's not a bad idea to add some better wire and your own relays so that you can run the high wattage lights without overheating the stock harness.
Old Jun 24, 2003 | 07:14 AM
|Bijan|'s Avatar
UCF Lexus
If you get another stock one, it's just gonna happen again. Get an upgraded wire harness. $30
Old Jun 24, 2003 | 07:16 AM
nubiannupe's Avatar
OG Maxima.org Member
...either that, or quit using those darned high-wattage bulbs!
Old Jun 24, 2003 | 07:37 AM
Freaknificent's Avatar
how do you put em in? i bought some from southwestautoworks awhile back and now my stock ones are going, so i wanna put these in but i'm not exactly a whiz with electrical stuff. anyone know of a step by step procedure?
Old Jun 24, 2003 | 07:52 AM
Michael's Avatar
Back in a 3rd Gen.
Well here is what I did to hook up mine...I got them from autodynamics.com
1. mount relays on side of engine bay or close to lights.
2. connect socket from original lights up to harness.
3. connect light sockets from harness to lights and ground the ground wire close by.
4. connect power wire for harness to pos of battery.
5. turn on lights and check to make sure they work.
yours maybe different than mind though but mine was plug and play.
here is what mine looks like:
Old Jun 24, 2003 | 07:56 AM
mine is nothing like that all it is is the actual harness with three wires coming out (positive, negative and ground)
Old Jun 24, 2003 | 08:01 AM
nubiannupe's Avatar
Positive, negative and ground??? Don't you mean low beam, high beam and ground?
Old Jun 24, 2003 | 08:30 AM
heh yea that makes sense i just assumes red was negative. (see above post about being a dunce when it comes to electrical stuff ) so do i just cut and splice the wires to the new harness?
Old Jun 25, 2003 | 10:20 AM
so i spliced them all together... initial test, seems everything works fine....
do i use the di-elctric(sp) grease in the harness now to help it from burning out again?
Old Jun 25, 2003 | 10:29 AM
nismo1989's Avatar
I have something similar, but now I don't have any high beams... not that I really need them anyway! lol
Old Jun 25, 2003 | 11:05 AM
Michael's Avatar
Back in a 3rd Gen.
hmm interesting...I just got a pm from someone yesterday that said they didnt have high beams and they had a harness like that. Maybe its something with the 9004 harness or something. I have the 9005/9006 harness for my bmw lights and high and low beam both work fine.
Old Jun 25, 2003 | 11:09 AM
nismo1989's Avatar
Yeah, it's the 9004 harnesses that are like that. Kinda sucks, but I don't care really. I have HIDs down low and also higher wattage bulbs in the headlamps so I never worry about out driving my lights anyway.
Old Jun 25, 2003 | 08:33 PM
MaximaBalla's Avatar
I have the APC upgraded headlight wiring harness and my brights work? Let me tell you, when I installed that harness, it made a hell of a difference! Now, I can actually see my headlights in the rain!
doctorpullit
Oct 28, 2019 10:58 PM
doctorpullit
Mar 29, 2016 11:08 AM
magiconthetire
Oct 26, 2015 09:03 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Noela
Sep 26, 2015 08:22 AM
