how to remove climate control
Old Jun 26, 2003 | 11:09 PM
alane's Avatar
how do i remove the climate control thing in my 92 gxe? i cant figure out how to get the cover off
~andrew
Old Jun 26, 2003 | 11:12 PM
KLoWnPR109's Avatar
it comes out as a unit. You have to remove the stereo trim piece first. There are four screws, two above the headunit, and two below the coin tray and lighter. You should see the screws to get it out after that
Old Jun 26, 2003 | 11:13 PM
alane's Avatar
where are these four screw? i can see them... i dont see any screws on this big black plastic peice that is in the way...all i saw was one screw when i took out the ash tray...
~andrew
Old Jun 26, 2003 | 11:21 PM
jaguax's Avatar
That big black plastic piece needs to be removed. You need to pull the ash tray out(there will be a thing inside the ash tray that says push - push that piece down and pull the ash tray out) There is 1 or 2 screws behind that ash tray that need to be removed. Before pulling the black center console plastic piece out, you should remove the plastic piece that surrounds the shifter. This is done by simply prying it up with a screwdriver(it snaps right back in when you need to put it back on). After removing that you can proceed to remove the center console plastic piece by prying the top out with a small screwdriver and pulling the rest out with your hands(it just snaps in and out, no screws hold it except the one(s) behind the ashtray. After you're done with all of this just unplug the connectors(transmission switch, cigarette lighter, and hazard lights) and remove the center console piece. You should be able to figure it out from there. Good luck dude.
Old Jun 27, 2003 | 07:32 AM
alane's Avatar
ah, so only the one screw, then it snaps, thanks a lot!
!andrew
mikeg75
Nov 30, 2015 05:12 PM
Turbonut
46
Oct 21, 2015 08:28 PM
Max139617
Sep 29, 2015 06:44 PM
EdRomo86
Sep 12, 2015 07:49 PM
