1990 Max SE engine to sentra?
Old Jul 2, 2003 | 03:56 PM
fiddlinmax's Avatar
My 1990 Maxima SE has a transmission going out, but the engine is strong. I haven't found any transmission donor Maximas or any with a blown motor to do a swap yet. Does anyone know if I could put my engine in a sentra? If so what year and model would work? Does it require serious modification. If it worked, I'd have a kickin' sentra. I did a quick search on this and didn't find anything.
Any suggestions
Fid
Old Jul 2, 2003 | 04:01 PM
Menel's Avatar
1992 Maxima SE
with enough time and money. . . .
Old Jul 2, 2003 | 04:41 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
and what tranny would you use?...
think people
Old Jul 2, 2003 | 05:43 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
think people
10 speed from a Huffy....
Old Jul 2, 2003 | 05:54 PM
Slamnasty's Avatar
Well, I don't think such a conversion as this has ever been tried, which may explain why there's no info on it. The transmission would be a huge problem...the Sentra tranny wouldn't be able to cope with the V6 power and torque characteristics.
Also, putting a 160HP V6 in a Sentra that came with an engine that probably already made at least 100 HP is a strange way to gain ponies. You'd be better off modding the 4-pot in the Sentra than swapping for a V6. That's how I see it anyways.
Old Jul 2, 2003 | 06:00 PM
DA-MAX's Avatar
thats not even the point...who says they will even bolt together.
Old Jul 2, 2003 | 06:02 PM
Cutler's Avatar
the sentra tranny is for a 4-banger economy car, not a maxima v6
Old Jul 2, 2003 | 07:56 PM
fiddlinmax's Avatar
Thanks for the replies. If I remember right, there was a Red 94 Sentra SE-R on EBay with a Maxima engine in it. The guy said it ran OK but you could hear the engine clunk into the firewall when you put it in reverse.
Old Jul 2, 2003 | 08:54 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
so talk to him
Old Jul 3, 2003 | 03:30 AM
nismobaron's Avatar
Re: 1990 Max SE engine to sentra?
Any suggestions
Fid
Dumbass!!! Even if you could squeeze max engine & tranny into Sentra (after re-positioning the firewall or adding a new nose...), you'd have to change front suspension & brakes, figure out where to mount the remote brake booster, locate the battery in the trunk - along with the lead weights to offset the extra weight in the front...) & then modify the rear suspension & brakes to compensate for the extra weight in the rear. Plus... try & get that bad boy certified! Word to the wise:
REPLACE YOUR TRANSMISSION - IT'LL BE CHEAPER & QUICKER...
NismoBaron Knows Best
Old Jul 3, 2003 | 08:26 AM
nismo-max500's Avatar
the extra weight of the V6 would probabaly make the handling suck in the sentra, for your question i would say , no
Old Jul 4, 2003 | 03:05 PM
bonzelite's Avatar
for Sentra, go SR20DET from Silvia or Bluebird (Turbo vol.19, #3, March 2003). or yank SR20DE from G20/Primera and turbo it (Sport Compact Car vol 13, #12, Dec 2001). nevermind Maxima.
MAXSE5SPD
Sep 17, 2022 04:00 AM
MaxLife17
Sep 8, 2015 02:36 PM
Hailstatejig
Sep 2, 2015 06:52 AM
A32goldylocks
Sep 2, 2015 06:39 AM
