MAF Sensor Help
Old Jul 4, 2003 | 11:49 PM
94maximahurricane's Avatar
MAF Sensor Help
Hi, I've done a lot of searching and looking through my Haynes manual, but I can't find the answer to my questions. So, maybe someone can help me out. Has anyone ever tested the voltage on the MAF sensor? If so, what wire is the 5 volt wire? And which wire or wires are the ground wires? I think that there might be 2 ground wires. Am I wrong? If anyone could help me out, that would be great. Thanks!!!
Old Jul 5, 2003 | 08:37 AM
If no one knows off the top of their head. Does anyone know, where I might be able to find this info.? Thanks again.
Old Jul 5, 2003 | 08:49 AM
Matt93SE's Avatar
STFU n00b!
it's in the nissan FSM. buy one. you won't regret it.
Old Jul 5, 2003 | 10:33 AM
Mizeree_X's Avatar
Getting back to his roots
Old Jul 9, 2003 | 09:30 AM
So, on one has ever tested these wires before?
Old Jul 12, 2003 | 08:28 AM
DPDISXR4Ti's Avatar
I will test the two I have on the bench and supply the info, but I need to know the following:
1) Which circuit (A, C, D, or E?) is source voltage, and is it a 5 or 12v source?
2) Which circuit is ground?
So far, all I know is that circuit B is the output. Can someone check the schematic and report back?
Thanks,
Brad
Old Jul 18, 2003 | 07:09 PM
DPDISXR4Ti's Avatar
Thanks,
Brad
Someone with a FSM and/or schematic must have this info, no?
C'mon, can't someone lend a brother a hand???
Brad
Old Jul 18, 2003 | 07:41 PM
subs1000w's Avatar
i have tested mine to see i could hook up an safc because i was told one of the wires needs to be 5v instead of 12v and mine has a 5v wire but i dont remember which one why dont oyu go test yours its really easy with a meter
Old Jul 18, 2003 | 07:51 PM
DPDISXR4Ti's Avatar
Agree it would be easy to check, but only if I had a running Maxima to check it on!
Brad
Old Jul 22, 2003 | 03:26 PM
DPDISXR4Ti's Avatar
Someone must know this info, right? Obviously it's not me at the moment. All I really need to know is which circuit is source voltage, and is it 5 or 12 volt. Despite what it says next to my user ID, I actually HAVE read the FAQ and searched the archives, but no luck. Do I have to resort to bribes???
Brad
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
