disabling ABS
Old Jul 18, 2003 | 11:13 PM
sTAE's Avatar
disabling ABS
I did a search but did not come up with any useful info on this. But does anyone know how to safely disable the ABS system? i know that disabling the ABS system probably isn't safe...but i'd like to do that anyway. temporarily at least.
I was planning on simply disconnecting the 4 wires that plug into it. Is that all there is to it? or am i missing something?
any help is appreciated.
Old Jul 19, 2003 | 07:51 AM
adroga's Avatar
All I think you have to do is pull out the ABS fuse and voila.. disabled.
Old Jul 19, 2003 | 08:46 AM
sTAE's Avatar
Ok, i looked all over in the FSM but can't find where it is located. Do you know?
Old Jul 19, 2003 | 01:22 PM
alane's Avatar
um, could it be with all the other fuses? under the steering wheel close to the door?? LOL
Old Jul 19, 2003 | 01:56 PM
sTAE's Avatar
actually, it's not. for now, i went ahead and disconnected the 3 wiring harnesses that lead into the actuator. Hopefully, that should work.
Old Jul 19, 2003 | 03:34 PM
alane's Avatar
you should be able to tell if it worked. if ads has a prob, the abs light on your instrument cluster (dash) should light up.
ãndrew
Old Jul 21, 2003 | 12:34 AM
Maxdout
i pulled the fuse and my front wheels got extremly hot and my front rotors and pads were smoking. do you think if i pull the wire harnesses it would be any different, or should i say any better?i would appreciate any help i can get. my accuator keeps buzzing, just looking for a temp. way to fix this
Old Jul 21, 2003 | 01:09 AM
MrGone's Avatar
Have you considered pulling the relays?
best advice, look at a manual, figure out how it all works, then decide how to go about disabling it. Get a througho under standing on how the system works before you tamper with it. Once you under stand how it works.
I have a feeling that people are hesitant to help you out because this is really a dangerous and "worthless" modification.
Old Jul 21, 2003 | 01:23 AM
Maxdout
i appreciate it, good looking out, i will try the relays, the reason i am asking is my abs accuator keeps buzzing and draining my battery any other suggestions?
Old Jul 21, 2003 | 06:26 AM
sTAE's Avatar
the same thing is happening with my car. I disconnected the 3 wires leading into the actuator but it still keeps buzzing.
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
leatherneck
Sep 30, 2015 09:16 PM
Djsmaxima
Sep 14, 2015 11:58 PM
maximusrising
Sep 2, 2015 09:55 AM
