5spd tranny question
Old Jul 21, 2003 | 11:26 PM
bgcease92's Avatar
i thinking of buying this used 94 ve 5spd as a parts car ,but the seller said that the speed pump is bad. Does anyone know how much a speed pump is and is it difficult to attain. no flaming eithier
Old Jul 22, 2003 | 12:25 AM
subs1000w's Avatar
what is a speed pump id like to know because ive never herd of it what do you care anyway if its going to be a parts car
Old Jul 22, 2003 | 10:36 PM
bgcease92's Avatar
i have to care if i want to do a 5spd swap.
Old Jul 23, 2003 | 05:35 AM
DARHAW-MAX's Avatar
Speed pump? Do you mean the power acuator (sp)?
Old Jul 24, 2003 | 12:21 AM
bgcease92's Avatar
i idon't know what i need but some told me it was speed pump. I don't know much about 5spds. all i know my clutch pedal is all the way to the floor and it doesn't rise or fall by it self and i not sure whats wrong with it. Any suggestions?
Old Jul 24, 2003 | 04:46 AM
RosenKen's Avatar
I have never ever heard of a speed pump ever, and I know quite a bit about cars. I guarantee if you go to a Nissan dealer and ask for a new "speed pump", the parts guy will outright laugh at you.
anyway, the clutch pedal problem is caused by a lack of fluid in the lines. You either have a leak or a worn out clutch master or slave cylinder. First, check the clutch fluid level under the hood (small cylinder in the upper right corner).
Fixing this problem shouldnt cost you that much.
Old Jul 24, 2003 | 08:26 AM
bgcease92's Avatar
thanks for the information rosenken. I checked uder the hood and the clutch fluid thing was empty. i going to try to fill it up and see if thats the culprit behind the clutch problem.
Old Jul 29, 2003 | 03:37 AM
DARHAW-MAX's Avatar
You are going to have to bleed it also.
Old Jul 29, 2003 | 06:47 AM
Cliff Clavin's Avatar
Way out West
It sounds like the slave cylinder is bad. That happened on my first Maxima, and it less than $200 including labor to have replaced.
Oh, and bgcease, check your email...
MaxStock
Dec 5, 2016 05:19 PM
Socalstillen
Sep 20, 2015 11:46 PM
iamute
Sep 20, 2015 05:22 PM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
