front exhaust pipe
Old Jul 28, 2003 | 03:20 PM
Whitelegend's Avatar
front exhaust pipe
Hi,
I tried to search for this, but the search engine was turned off.
Anyways, the front exhaust pipe on my 93 SE has a leak, it needs to be replaced. The muffler shop quoted me $600. That's insane, is there a cheaper alternative to this. Can I get the warp speed Y-pipe to replace that front exhaust pipe in my Maxima, or is there anything cheaper? Also is this something I can do myself, what are some problems I might run into? Thanks in advance
Old Jul 28, 2003 | 03:34 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
go Warpspeed you'll get a performance increase and still pay less than replacing it with the restrictive OEM pipe
Old Jul 28, 2003 | 03:37 PM
subs1000w's Avatar
if by front exhaust pipe you mean y pipe and not manifold yes a 200$ warpspeed y pipe will fix the leak and its 8 bolts and an o2 sensor to change and is very easy even easier if you have an impact wrench
Old Jul 28, 2003 | 03:45 PM
thanks for your prompt reply, I really appreciated.
Where can I get the best price for the Warpspeed?
I found one on Ebay for $200. Here's a link
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2425032012
What's the difference between Mandrel and non Mandrel bent? Is one cheaper than the other? Also does this comes with everything I need to install it? Thanks in Advance
Old Jul 28, 2003 | 03:51 PM
Gjohnson's Avatar
I know you can go to WWW.warpspeedperformance.com and order it directly. I'm not sure what the price difference is, I haven't picked one up yet.
Old Jul 29, 2003 | 12:28 AM
subs1000w's Avatar
mandrel bent will flow slightly better than regular pressure bending and the cost will be slightly higher although if you dont care about performance just get the cheaper one
JRod28
Dec 29, 2023 09:56 PM
Matt93SE
May 24, 2019 02:58 PM
rbuswell
Nov 12, 2016 04:11 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
