How to install the entire Bose System on another car?
Old Feb 6, 2001 | 01:38 PM
Richy92SE's Avatar
My Bose System (HU, speakers, amps) are in great shape although I put in a Eclipse head unit and Pioneers 6 ½ in front and 6 X 9’s 3 ways on the back, but I have a Ram Truck 90’ that doesn’t has Audio so I’m planning to put the bose on the truck. Are there any instructions on how to do this job? Any one has done this?
Please help I don’t have money to spend in another system so I will have to take advantage of the Bose System.
Thanks in advance
Richy
Old Feb 6, 2001 | 01:45 PM
«§»Craig B«§»'s Avatar
you should be able to use it
keep the amps with the speakers and wire the HU into a Nissan harness that you can buy from Best Buy or any audio shop; from there, splice those wires into the existing harness (if there is one)
then put the speakers and amps in with the 2 wires coming into it
it shouldn't be that hard other than figuring out the colors which can probably be found by searching on here; if not, I can look them up for you
if there isn't any audio system at all, you can do it, but you will have to run wires to the speakers (in the doors or wherever you want to put them); you will also need to find constant power, accessory power, ground, and a few other thigns, but it can be done and isn't too hard
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
stromm
Aug 27, 2015 04:13 PM
Team STILLEN
Aug 10, 2015 04:29 PM
