Rotor Question
Old Aug 3, 2003 | 10:26 PM
Tall's Avatar
Rotor Question
I am trying to replace my rotor but it won't come off! Yes, I read about it. Yes, I took the damn screw out. I really yanked on that thing and it won't move. Any tips?
Old Aug 4, 2003 | 02:32 AM
DARHAW-MAX's Avatar
:GOTME:
Old Aug 4, 2003 | 03:10 AM
sukoshiyoshi's Avatar
there are two screws on the hub of the rotor. I don' remember the exact size. But just evenly un screw them and it should lossen them up. If you are gonna replace the whole rotor the hammer will also do the job.
sukoshiyoshi
Old Aug 4, 2003 | 08:47 AM
Tall's Avatar
Are you talking about the two screws that are on that metal plate? I took those out and it made no difference.
Old Aug 4, 2003 | 10:46 AM
snowman2155's Avatar
Mine didn't have screws holding the rotor on. Just take off the calliper and the bracket that the pads are in. It should come right off.
Old Aug 4, 2003 | 12:04 PM
Tall's Avatar
Talking about CAP AND ROTOR, not the brakes
Sorry to be misleading, but I am talking about the rotor on the distributor.
Old Aug 4, 2003 | 12:15 PM
Oh, that explains everything.....LOL
Old Aug 4, 2003 | 12:43 PM
jaguax's Avatar
Dude there is one screw holding it on. It is on the side of the rotor and cannot be seen from the top. Tilt your head and look at the side of the rotor there is one little screw there holding it on.
Old Aug 4, 2003 | 02:13 PM
Tall's Avatar
If you would read my first post...
"Yes, I took the damn screw out."
It's out, it should come right off. It's not coming right off. I am pretty sure it's the original one and it ain't moving, which is why I am asking the question.
Old Aug 4, 2003 | 07:52 PM
jkmay01's Avatar
Lil 8
i had the same prob use a little lubricant on the center rod that mounts the rotor, just try working in the lubricant and use a pair of pliers to pull up and you work the rotor is should eventually come off. The heat from the current and engine sometimes seizes the rotor on!!! Let me know
Old Aug 4, 2003 | 11:14 PM
Tall's Avatar
I'm just afraid I'll break it getting it off!
Old Aug 5, 2003 | 03:37 AM
sukoshiyoshi
I meant to write...there are two places where you can put bolts in to losen the rotor........but I guess i was reffering to the wrong rotor anyways....
Old Aug 5, 2003 | 06:01 AM
Bill Doran's Avatar
I had same problem. Just a note of caution be careful not to try to twist rotor off. I used vise grips and the twisting motion damaged the optical timing plate that is attached to the shaft the rotor attaches to. This required repacing the distributor. Even after removing old distibutor, I couldn't remove rotor before I turned in core. For the life of me I can't understand why it was frozen to shaft.
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
trsandrew
Oct 25, 2015 02:47 PM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
