Auto and Manual Trans Comparison Question
Old Aug 4, 2003 | 09:41 PM
ILOVEMYSE's Avatar
I have seen numerous numerous post about auto trannys failing Im thinking of making my next Maxima a stick. I have had four 3rd gens and they have all been autos. I want to know do manual last longer than autos and if so what makes manual trans last longer than autos.
Old Aug 4, 2003 | 09:54 PM
Maxima NutBag's Avatar
my tranny died at 148k, had it rebuilt. one factor that makes automatic transmissions wear out faster is heat (correct?).plus, they're more complex and have more work to do since there is no physical clutch.
Old Aug 4, 2003 | 09:57 PM
mtcookson's Avatar
borg warner sucks. that's the main reason, lol.
but like said above, auto trannies are more complex than manual trannies and that's generally why they wear out faster.
Old Aug 4, 2003 | 10:32 PM
KLoWnPR109's Avatar
depends on how you drive it
Old Aug 4, 2003 | 11:15 PM
subs1000w's Avatar
in general all autos will die faster and cost more to repair than manuals dont matter who made it and manuals do suffer from bearing ,syncro and clutch failier but usaually last longer except when you drive like me mine needed repair at 105k but if i drove an auto (which i never will) i would estimate it would die at about 80k if you get my idea
Old Aug 5, 2003 | 11:45 AM
mtcookson's Avatar
actually, it does matter who makes it. different companies make things of different quality.
our brand new chevy express van with the 6 liter v8 and automatic transmission is at about 20,000 miles now. at 14,000 mile the tranny had already started to slip. we took it in to have it checked out and for some strange reason the tranny fluid was low. the guys refilled it and it has still slipped again since then. more than likely we'll have to get a new tranny installed (under warranty luckily). i'm not sure who makes the tranny in it but i know it's of low quality.
Old Aug 5, 2003 | 03:11 PM
MrGone's Avatar
Borg Warner Transfer Cases arent too bad though
Klown is right though, it all depends on how you drive them.
Old Aug 5, 2003 | 03:28 PM
mtcookson's Avatar
the 92-94 maxima trannies seem to hold out better than the 89-91 trannies do. i wonder what they did differently.
Old Aug 6, 2003 | 10:44 AM
maxda92gxe's Avatar
i hope i dont get tranny troubles
Old Aug 6, 2003 | 12:45 PM
ghostmax's Avatar
the manual trannies in 90-91 had improved bearings.
supposedly the autos were beefed up (better internals) starting in 92. my 92 auto gave out at ~75K, but's that's because i didn't check the tranny fluid. got it rebuilt and put in a tranny cooler too. now at 115K, and it slips every so often.
driving style and maintenance (flushing, etc) are probably the COD of autos/sticks.
Old Aug 6, 2003 | 12:48 PM
mtcookson's Avatar
do you mean 92-94 had improved bearings? my input shaft bearing went out at 13x,xxx miles which would have been a cheap fix if i had caught the problem sooner. although, it still only cost me about 350 to fix it since i did it myself.
Old Aug 6, 2003 | 01:01 PM
MrGone's Avatar
VE trannys are built up more.
Probably because of the power.
Old Aug 6, 2003 | 01:06 PM
ghostmax's Avatar
well the 90-91 had improved bearings over the 87-89 manuals (for VG). i assume the 92-94 manuals were different than the VG trannies.
Old Aug 6, 2003 | 01:25 PM
MrGone's Avatar
I believe you can bolt up all VE trannies to VG's, and since they have larger axles, I'd consider doing it for a higher HP VG
Old Aug 6, 2003 | 01:29 PM
ghostmax's Avatar
the internals are probably different though.
Old Aug 6, 2003 | 01:34 PM
mtcookson's Avatar
you are right. they can be switched. you just need to get the driver's side axle if i remember correctly. the case is a bit bigger due to the lsd making the axle shorter. if probably wouldn't hurt to use both axles though. i am planning on using the lsd ve tranny sometime since i have the turbo engine.
Old Aug 6, 2003 | 01:36 PM
ghostmax's Avatar
don't forget the VE hubs too.
Old Aug 6, 2003 | 01:38 PM
mtcookson's Avatar
i didn't think those had to be changed. do they have a different amount of teeth?
Old Aug 6, 2003 | 01:43 PM
ghostmax's Avatar
not having done the swap, i couldn't tell you first hand. but i would ask kaleb or a junk yard. my feeling though is that you will have to.
Old Aug 6, 2003 | 01:46 PM
mtcookson's Avatar
hmm... thanks for the info. i'll check that out.
Old Aug 6, 2003 | 02:08 PM
THX's Avatar
THX
Hallelujah
If you do go for an auto be sure to get a tranny cooler installed. Less than $100 and will lengthen the life of your tranny. Mine started slipping at 172k but it seems to work ok after it gets warmed up. The car is now at 180k with the same problems.. my next 3rd gen will definitely be stsick.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
Maxboy23
Sep 4, 2015 06:04 PM
jfl330
Sep 4, 2015 01:44 PM
Johnny9595
Sep 3, 2015 05:18 AM
