Loose brake rotor
Old Aug 7, 2003 | 08:53 PM
Nmax92's Avatar
Loose brake rotor
I've noticed when I hit a bump I hear a rattling sound coming mostly from my driver's side. I took off the wheel and noticed my front rotors are wobbly, could that be the source of the rattling noise?
There are no bolts to hold it in place. If I do need bolts what size to get? If the rotors are not the problem then what is? HELP!!!
I sounds like my front end is gonna fall off or something
Old Aug 7, 2003 | 09:31 PM
DanNY's Avatar
Ad·min·is·tra·tor
Re: Loose brake rotor
well do this..
put the wheel back on and keep your eye on the rotor as you tighten the wheel lug nuts.
let me know what happens.
Old Aug 7, 2003 | 10:56 PM
DARHAW-MAX's Avatar
When the wheel is off, the rotor will be loose. The same lug nuts that holds the wheel on are also what tightens the rotor to the hub. In other words, your problem is not a loose rotor.
What you will need to do is put the wheel back on and shake it while you observe the suspension components. A rattling should could be any of a 100 things.
Old Aug 8, 2003 | 12:14 PM
Nmax92's Avatar
Re: Re: Loose brake rotor
Thanks for the feedback. I did what you said to do. With the wheel on I turn it to left and right and feel play like it loose. I just changed my driver's side axel and ball joints.
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
