fog light bulb replacement
Old Aug 12, 2003 | 08:33 AM
trenddiggy's Avatar
wutup!! how do I replace the fog light bulbs on my 89 se???
hit me back
Old Aug 12, 2003 | 08:40 AM
D-sta's Avatar
To replace the bulb on the stock fog light you need to get under and behind the fog assembly, directly above you will two 10mm bolts, you might want to soak them with Wd-40 and then remove them. Once you remove the two 10mm bolts the fog light assembly drops and all you need to do is disconnect the connector and take it away from the car. Now there will be two phillips screws on the back side of the assembly, remove them and then the glass should separate from the housing, once that is removed you will see the H3 bulb connector, disconnect it and then release the clip holding the bulb inside to remove it. Installing it back is just taking the steps I gave you backwards.
Old Aug 12, 2003 | 08:59 AM
Gjohnson's Avatar
Yea, what he said
Man I talked to one of my boys yesterday that has a Max and he said that he took his Max to the dealership and asked them how much they charged to change the bulb on the fog lights and they qouted him $70 dollars. He said he was like "No, not the whole assembly, just to change the bulb inside" and they said yea $70 dollars. He laughed and walked away. (Of course!)
Old Aug 12, 2003 | 09:00 AM
D-sta's Avatar
Damn dealers are out of their minds.
Old Aug 12, 2003 | 10:48 AM
Gjohnson's Avatar
Old Aug 13, 2003 | 01:05 AM
DARHAW-MAX's Avatar
And that is why we have forums such as this.
Old Aug 13, 2003 | 01:07 AM
D-sta's Avatar
Oh really thanks I didn't know that
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
MikesChevelle
Aug 6, 2015 11:36 AM
