auto tranny...
auto tranny...
Okay, tried to search but no luck.
Tranny won't upshift from 2-3 under moderate-hard to hard acceleration. Will upshift in all other gears under hard acceleration & kicks down no problem. Just the 2-3 upshift. Take foot off the gas when engine starts spinning and it'll shift up. Drive in 'easy-livin' cruise mode' and it'll shift up. Have just changed the oil (old oil in good condition) and no change. Question: am I looking at a rebuilt/replace tranny soonish or can I make adjustment in valve body?
Re: auto tranny...
I'd like to know what that is too...I have a '94 Max that does the exact same thing...im gonna put some tranny treatment i got a pep boys in it to see if it helps. Ill let you know if it does. If anyone else knows how to fix let me know.
Re: Re: auto tranny...
Ran a diagnostic test on tranny - all good Curious to see if tranny treatment helps - I'm of the mind that additives only aid the tranny to fail quicker... It's probably a worn or mal-adjusted band. If anyone has a FSM that tells you how to adjust the bands, please write it up
PS: Had another Nissan a few years back that had a tranny with the valve body on top & band adjustment was reasonably easy.
I wouldn't bother with the trans treatment. I bought some trans-tune by Seafoam the other day, and it is supposed to be (allegedly) the best kind out there (maybe Lucas oil, too) Anyways, it did not help a bit- but, it sounds like your trannys are in better shape than mine. I just had to do a rebuild...
AaronL
08-08-2020 10:31 AM
Maximeltman
09-28-2015 07:19 PM
