shaking at low rpms
Old Aug 17, 2003 | 10:52 PM
Bluemax92's Avatar
shaking at low rpms
MY 92 SE max seems to have developed a new problem. Just recently it developed a vibration in that i can feel in the steering wheel, it does it at low rpms and only really becomes apparent in any gear other than park or neutral, i have an auto. The car already has the symtoms of a failed fuel injector and i would just like any advice you all have to give, thanks
Old Aug 18, 2003 | 06:48 AM
jwhite's Avatar
Re: shaking at low rpms
Could possible be out of alignment or the wheels out of balance. Have you hit any big pot-holes lately?
Old Aug 18, 2003 | 06:57 AM
DARHAW-MAX's Avatar
If you are getting an engine vibration that you can feel through the wheel while the car is stationary, however, in gear, a failed injector will give you the vibration that you are describing. Also, a misfiring cylinder will have a similar symptom. Another possibilty could be a bad motor mount. However, since you said that you already have the symptons of a failed injector, that is most likely your cause.
user 11122324
42
Jul 18, 2022 03:35 PM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
