Got My Strut Bar Today But I Cant Get The Damn Strut Tower Bolts Off
Old Aug 19, 2003 | 02:57 PM
ILOVEMYSE's Avatar
I see that just about everyone on here has a fstb how did you get the bolts off. I sprayed some WD40 on them and let it sit for a while and still nothing how did everyone get theres to come off.
Old Aug 19, 2003 | 03:05 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
are you using a torque wrench?? air tools would be a sure bet to get them off.
HTPerformance's Avatar
-Use a breaker bar-
Did you try using a breaker bar? Usually a straight 18" or larger metal bar with the socket attachment. If you dont have one you can get it at a hardware store or sears, or you can put a piece of pipe over the ratchet/wrench that you are using. You need more leverage to increase the amount of torgue on the bolt.
Brian
If that doesnt work, WD-40 is kiddie spray, compared to PB B'LASTER, get some of that at the local auto supply store for about $3.
Cheers.
Old Aug 19, 2003 | 05:57 PM
Matt93SE's Avatar
STFU n00b!
find whoever tightened those bolts and kill them. they're only supposed to be torqued to 32 ft-lb.
Old Aug 19, 2003 | 08:49 PM
Bman's Avatar
Yeah as I recall, they weren't really that hard to get off with a medium sized ratchet.
The FSM actually suggests replacing those nuts once they are off. I don't think most people here do this (I didn't), but since these seem to be either frozen or torqued out the wazoo, I'd really think about getting new ones.
Side note: I love looking at my new 18" Sears 1/2" drive breaker bar.
Old Aug 19, 2003 | 09:10 PM
vwink182's Avatar
Use your muscles! i got mine of with just a normal rachet. GL dude.
Old Aug 19, 2003 | 10:05 PM
MrGone's Avatar
I still need to return an 18" breaker for a 24" breaker mmmmmm
btw, use 6 point sockets when you really have to work on it to get it off. chances are so might higher you'll screw up with a 12 point socket.
Old Aug 19, 2003 | 11:07 PM
DARHAW-MAX's Avatar
I have the same problem. As a matter of fact, one of the bolts on my driver's side is torqued so tight, it is starting to round out. I have used my 18" breaker bar and a pnuematic gun. It is starting to look as if I may have to have the bolt cut off. Oh well, I need new strut insulators anyway.
Old Aug 19, 2003 | 11:11 PM
MrGone's Avatar
that happened to my old 93, one of the strut bolts was on sooo tight, probably because of age. anyway, we had to pound a socket on it to get it to come off. I almost owed my friend a new socket.
Old Aug 19, 2003 | 11:37 PM
DARHAW-MAX's Avatar
What size did you use? I know that the bolts are 13mm. Hammering on a 12mm socket crossed my mind. Is this what you did?
Old Aug 20, 2003 | 01:05 AM
Fredrik's Avatar
Cut them away and replace them with new ones but be careful!
Old Aug 20, 2003 | 01:30 AM
MrGone's Avatar
I dont remember, it was WAYYYY too long ago
Old Aug 20, 2003 | 07:33 AM
Freaknificent's Avatar
hit the gym, beef up then go back ou and own that damned nut!
i was able to get mine off with a regular ratchet and muscle power and a few odd groans and screams.....
Matt93SE's Avatar
STFU n00b!
ummm, the bolts should be 14mm... they are from the factory. there are only about three 13mm bolts on the entire car when it came from Nissan, and those aren't it.
Old Aug 20, 2003 | 01:12 PM
Cliff Clavin's Avatar
Way out West
Mine were all relatively easy to take off with a normal socket. After you get them off, be sure the next time you tighten them to the specified 32-40 lb ft.
I think there are several loosening agents available at most hardware stores that are much better than WD-40, too.
good luck and try not to break anything!
Old Aug 20, 2003 | 02:47 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
mine just came off with a regular ratchet, real easy too.
Old Aug 21, 2003 | 02:13 AM
DARHAW-MAX's Avatar
Yeah Matt, you are right. They are 14mm.
Old Aug 21, 2003 | 03:23 PM
MrGone's Avatar
arent those 3 13mm bolts on the transmission? (5spd VE atleast)?
lowpost99
Oct 26, 2025 06:53 PM
matts95max
Apr 23, 2025 10:44 AM
t6378tp
Sep 29, 2018 04:27 PM
Stagnet04
Sep 14, 2015 11:28 PM
