Lowering the rear only
Old Aug 20, 2003 | 06:55 PM
anaximander's Avatar
What are the pro's and con's of this undertaking? I'm planning on having the eibachs installed along with konis, FSTB, and ADDCO RSB.
I don't want to lower the front because it happened a couple times that when I went fast over little hills/potholes, the car scratched the ground in the front.
Old Aug 20, 2003 | 07:52 PM
Method Max's Avatar
It's gonna look ODD! I'll tell you that. Is it gonna be a drag VG? lower the whole thing man
Old Aug 20, 2003 | 08:06 PM
It's not gonna be a drag. I like to go fast in small/unfrequented streets since there's a smaller chance of getting clocked and it's much more challenging than a nice straight road. The disadvantage is that these roads are often bad and I don't wanna hit the ground with the front too many times.
Old Aug 20, 2003 | 08:14 PM
todamax's Avatar
1) I've never hit the ground on 'bad' roads in 3 years of driving on eibachs. If your hitting the ground, you ARE driving TOO FAST for the road to support. My car is lowered with eibach and has the ST sway kit on it. The front sway bar hangs almost an inch lower than the stock one. Point is, at that spot my car is 2.5 inches lower than stock. Bad roads/construction still isn't a problem - but I'm not driving like a crazy.
2)Having a lowered rear will throw off the handling balance of the car. Most likely it will not improve the handling - it will just make it worse.
Old Aug 20, 2003 | 08:15 PM
todamax's Avatar
also, the front springs do most of the cornering work IIRC.
Old Aug 20, 2003 | 08:33 PM
Thanks. However I'm having the visual impression that the stock suspension is not "even", i.e. the front is sitting lower than the back. I thought that lowering the rear would level the suspension out, reduce the center of gravity, and hence improve the handling.
On a side note, I sometimes do drive like crazy.
Old Aug 20, 2003 | 08:59 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
lol
Old Aug 20, 2003 | 09:02 PM
Laughing at the idea or the exposition?
Old Aug 20, 2003 | 09:19 PM
todamax's Avatar
Stock springs:
Eibach:
so... ride height slightly lower in back on both.
Old Aug 20, 2003 | 09:27 PM
Irish's Avatar
This is a democracy
would it be ok to ride on lowering springs and not new struts for say like 2-3 month
Old Aug 20, 2003 | 09:28 PM
Bman's Avatar
I agree - the back looks lower even if the ride height is correct because the rear fender lip is closer to the ground. If anything, I'd lower the front and leave the back alone.
Old Aug 20, 2003 | 09:58 PM
Thanks for the perspective, toda. That makes me reconsider any lowering due to my driving style. I may go with just strut and sway bars.
Huttig2009
Sep 25, 2015 03:31 PM
AcuraLegend
Sep 22, 2015 04:22 PM
homeyclaus
Sep 3, 2015 06:15 PM
Maximeltman
Aug 31, 2015 01:01 PM
laparka66
Aug 6, 2015 09:36 AM
