another (stupid) knock sensor question
Old Aug 21, 2003 | 06:21 PM
MaDMaX024's Avatar
i need to test my KS but unfortunately its out of the car (as is the rest of the powertrain). how do i go about doing this? is it the sensor itself that goes bad or the harness? it looks pretty silver to me, no evidence of dirt/grime/corrosion...
before the car was taken apart i did bypass the KS and there was no noticeable difference in performance but its since been sitting, moved around (possibly in a not very gentle way), not used...
thanks
Old Aug 21, 2003 | 06:44 PM
ljbrew001's Avatar
The FSM says be very careful not to bump the sensor for whatever that means. When my ks failed it indicated open with my fluke so I suspect the connector is corroded.
Old Aug 21, 2003 | 10:06 PM
MaDMaX024's Avatar
all my connectors look clean, i just need to test the sensor itself.
Old Aug 21, 2003 | 10:38 PM
DARHAW-MAX's Avatar
I would say that with the hassle that is required to change this sensor, install a new one now while you can. The recommended procedure is the change both the sensor and harness. Even if the old, good-looking sensor tested good, why take the chance and have it go out soon down the road. Add another five years and go new. Possibly, to enhance the new one's life, you can look into covering it with some high-temperature, insulating RTV to prevent moisture from seeping in.
Old Aug 22, 2003 | 10:18 AM
MaDMaX024's Avatar
i would except i'm out of money...if i absolutely have to get a new sensor, i will (meaning if mine is dead).
Old Aug 22, 2003 | 01:09 PM
ljbrew001's Avatar
Did you use a 470K resistor when you bypassed?
Old Aug 22, 2003 | 05:39 PM
MaDMaX024's Avatar
yes
mvm062
Nov 30, 2020 09:00 AM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
