No wheel alignment for the front?
Old Feb 11, 2001 | 08:28 PM
voltman's Avatar
I took my 94 GXE to a shop because it's drifting to the right. The place said there is no front caster/wheel alignment for the Maxima and other imports, so my only solution is to take the car to a body shop to stretch the frame. Does that sound right?
Old Feb 11, 2001 | 08:49 PM
mentor's Avatar
not really...
got my alignment done for $50 at some mechanics place, it has better steering now..
Old Feb 12, 2001 | 05:52 AM
brubenstein's Avatar
The only alignment parameter which is designed to be adjustable, front and back, is toe. Caster and camber has to be "kludged". Camber can be adjusted by adding special bolts, or top strut mounting plate.
Old Feb 12, 2001 | 08:30 AM
UndecidedMax's Avatar
i went to sears auto center, they did my front, but said my rear was locked up, and wasnt that bad so they left it, instead of f*ck*n it up, peace
Old Feb 12, 2001 | 09:02 AM
Weasel's Avatar
"Stretch the frame"? Is this a serious practice for a car that hasn't been in an accident? Just by what it says it sounds a little f-ed up.
Old Feb 12, 2001 | 10:03 AM
voltman's Avatar
I thought it sounded odd
I just wanted to make sure I wasn't the only one
Old Feb 12, 2001 | 06:07 PM
Marcus Cantu
Re: I thought it sounded odd
Stillen sells some special screws that adjust your front
camber +/- 3 degrees for around 30- 35 bucks.If you are lowering your car to 1.5" this would help.
homeyclaus
Sep 3, 2015 06:15 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
twotonezed
Aug 16, 2015 11:41 AM
Flores94
Aug 11, 2015 12:53 PM
BassAddictJ
Aug 4, 2015 11:38 AM
