autozone power steering hose-wrong #
Old Sep 9, 2003 | 10:49 AM
broncoguy's Avatar
this may have already been mentioned, but be careful if you go to Autozone to get your pressure hose. The one they have listed for the 90 GXE is wrong. Ask for the SE version. Unfortunately, I didn't realize that till I got my old one off, and didn't have another vehicle to go exchange it. Plus, on top of everything else, the hose they gave me is 20 bucks more...
Old Sep 9, 2003 | 11:00 AM
markmaxima's Avatar
power steering hose
how much for the hose at autozone?
Old Sep 9, 2003 | 11:34 AM
broncoguy's Avatar
well, the CORRECT one is only $21.99. The incorrect one that they will give you is $46.99. Make sure you get part # 71145, which they say is for an SE. It has straight connectors on each end, with the pin to keep the fitting from turning. The one that I got has a 90 degree bend on the lower end, and no pin. Anyone with a SE- does that sound correct for an SE car?
Old Sep 9, 2003 | 11:59 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
I've been through that on my old Max! but I've heard though that the 90 degree one will fit somehow...don't see how, but thats what I heard
Old Sep 9, 2003 | 12:41 PM
broncoguy's Avatar
Yep, it will fit, cause I did it out of necessity this weekend. Basically, you have to get the lower fitting started, then when it is almost tight, you pivot the hose back toward the firewall, which brings the whole thing away from the manifold....still ****es me off, though. They probably won't take it back, either, now that it's been installed...not that I really want to go back through the nightmare of installing it again anytime soon
Old Sep 9, 2003 | 11:02 PM
super32's Avatar
Donating member? what the?!
FOUND YOU!!! I was looking for this thread from the other thread.
Yah, you're right about the bends. I bought my hose from NAPA for 41 bucks, and it was with straight connectors on each end. 2 things warned me about Maxima model hoses...
First I went to parts bin , where they show the 2 different hoses for the SE and GXE. And second, the NAPA folks asked me which model.
Old Sep 10, 2003 | 06:05 AM
broncoguy's Avatar
Yeah, Autozone lists 2 different part numbers too, only they have them switched around, so if you go in and ask for one for a GXE, you get the one for the SE, and vice-versa.
Old Sep 10, 2003 | 07:32 AM
|Bijan|'s Avatar
UCF Lexus
I went thru hell tryin to make the L shaped one fit.
Old Sep 12, 2003 | 03:06 PM
MR FINGAHZ's Avatar
I just had one put on last week. I also purchased from autozone, and in reading I guess I got lucky because it fit. I have a 94 GXE
Old Sep 12, 2003 | 03:07 PM
MR FINGAHZ's Avatar
I PAYED I BELIEVE $36.99+ tax.
Old Oct 20, 2003 | 12:05 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
sorry to resurrect an old thread but whats one for the VE ? i mean is the one you can see from if you are standing in front of the car look to the back pass side.is that the high pressure hose or the low pressure hose ?
Old Oct 20, 2003 | 12:21 PM
MR FINGAHZ's Avatar
IT WAS ON THE TOP ON THE PASSENGER SIDE.
Old Oct 20, 2003 | 12:23 PM
YoU CaNt SeE mE
so is that the high pressure hose ??
Old Oct 20, 2003 | 12:26 PM
MR FINGAHZ's Avatar
That's what I was told. The power steering pressure hose is what I was told to ask for.
Old Oct 20, 2003 | 12:52 PM
YoU CaNt SeE mE
thanks !!!!
Old Oct 20, 2003 | 12:54 PM
Jack.'s Avatar
Yes, it's the high pressure hose that goes from the pump to the control valve? I got the one that has straight connectors, and i went to Pep boys. However, it didn't have the sure-fitting pins on the ends which, for security reasons, I wish it did. What a crap project, without the perfect tools (like in most car maintenence), it is very difficult. I made the mistake of starting with the top first. *rework.
Old Oct 20, 2003 | 12:58 PM
internetautomar's Avatar
mod or sell?
edelman cataloging:
89-91 SE = 71445
89-91 GXE = 71446
92-93 GXE (Sohc) = 71445
92-93 SE (DOHC) = 80100
94 GXE (sohc) = 71445
Now here's the goofy part:
94 with dohc with 24 valve engine = 80101 (same as 95-99)
94 with dohc without 24 valve engine = 80100 (same as 92-93)
So much for catalogs being perfect.
I didn't know the VE was available without 24V
71445 straight hose with banjo fitting at either end 28 1/16" long
71446 90degree bend at one end dtraight at the other, banjo fitting at either end 29 3/4" long
80100 = straight hose with banjo fitting at either end 28 3/4" long
80101 = straight hose with banjo fitting at either end 26 3/4" long
Old Oct 20, 2003 | 01:09 PM
broncoguy's Avatar
Yep, that about sums it up. That catalog is wrong. Should be 71145 for the 89-91 GXE. Excellent info!
lowpost99
Oct 26, 2025 06:53 PM
rbarnes
Dec 31, 2015 06:29 PM
Mochedda
Dec 15, 2015 11:27 AM
fastcarny
Oct 12, 2015 07:06 AM
ColdCananda
Sep 20, 2015 10:45 PM
